2014 Z1000
s man
Re: 2014 Z1000
Post by s man »
Wattie wrote:Yeah but the versys has had that for a couple of years.
2 power modes and 3 tc modes
ABS/ TC sensor is on the left side, thats why you cant see it..
Jeremyw01
Re: 2014 Z1000
Post by Jeremyw01 »
Looks like we will still have to wait for a z1000 with a 10 motor :?
Kermit
Re: 2014 Z1000
Post by Kermit »
Spec's
Augmenting its aggressive, sugomi styling is a list of performance upgrades: Some seen on its Ninja 1000 counterpart and some not. In the engine department the Z receives the same revised 1,043cc liquid-cooled inline-Four featuring new intake cams for improved low- to midrange torque, new cylinder connecting passageways for mid- to high-rpm performance, and new ECU settings along with equal-length velocity stacks make for sharper throttle response. Final-drive gearing was shortened while a new taller 6th gear helps maintain highway comfort. The airbox features new atmospheric intakes to enhance intake growl and a new non-woven air filter element.
New one-piece, monobloc, radial-mount front brake calipers are composed of differentiated diameter (32mm upper, and 30mm lower) pistons. While a new ABS pump new has a fluid pressure sensor that allows more precise control of line pressures. Brake pad compound has a higher coefficient of friction for improved stopping power.
Unlike the Ninja 1000, the Z1000 is suspended by a new Separate Function Fork-Big Piston (SFF-BP) fork. The separate function fork features dedicated preload adjustability in the left tube and dedicated damping pistons and adjustability in the right tube, while large-diameter damper piston is much larger than those used in traditional cartridge forks. SFF-BP design offers easy adjustability, by locating all adjusters in the caps at the top of the two fork tubes.
New, compact instrumentation features a dual element bar-graph tachometer with 0-4,000 rpm indicated vertically along the left edge of the lower display and a larger 4,000rpm+ tachometer filling the entire horizontal upper display. LCD information includes ABS and ECO indicators, digital speedometer, odometer, dual trip meter, clock, instant and average fuel consumption, coolant temperature, and low-fuel warning lamps.
Engine: Four-stroke, liquid-cooled, DOHC, four valves per cylinder, inline-four
Displacement: 1,043cc
Bore x stroke: 77.0 x 56.0mm
Compression ratio: 11.8:1
Fuel injection: DFI® with four 38mm Keihin throttle bodies, oval sub-throttles
Ignition: TCBI with digital advance
Transmission: Six-speed
Final drive: X-ring chain
Rake / trail: 24.5 degrees / 4.0 in.
Frame type: Aluminum Backbone
Front tire: 120/70 ZR17
Rear tire: 190/50 ZR17
Wheelbase: 56.5 in.
Front suspension / wheel travel: 41 mm inverted SFF-BP fork with stepless compression and rebound damping and spring preload adjustability / 4.7 in.
Rear suspension / wheel travel: Horizontal monoshock with stepless rebound damping, remotely adjustable spring preload / 4.8 in.
Front brakes: Dual 310mm petal-type rotors with radial-mount four-piston monobloc calipers and ABS
Rear brake: Single 250mm petal-type rotor with single-piston caliper and ABS
Overall length: 80.5 in.
Overall width: 31.1 in.
Overall height: 41.5 in.
Seat height: 32.1 in.
Curb weight: 487.3 lbs.
Fuel capacity: 4.5 gal.
Color choices: Golden Blazed Green / Metallic Graphite Gray
dutchy
Re: 2014 Z1000
Post by dutchy »
Just seen a pic of the green one. Not sure about that headlight. :-?
dutchy
Re: 2014 Z1000
Post by dutchy »
Re: 2014 Z1000
The more I see it the more I like it. I think it's a winner. Sure it's no ZRX but what can you expect :)
dutchy
Re: 2014 Z1000
Post by dutchy »
I'm still undecided. I think if I saw it in the flesh of love it.
Re: 2014 Z1000
Glen wrote:The more I see it the more I like it. I think it's a winner. Sure it's no ZRX but what can you expect :)
The more I see it, the more I want to ride my ZRX. I have to say I am more a fan of the 2010-2013 model. The new one needs to have a DB screen fitment availability (it doesnt seem to have one from what I can see), they look soooooo much better. Just check the Hoff's or Rod's or Carbon Col's or Mick C's for proof of that ;)
But I do like the new S1000R BMW
Re: 2014 Z1000
Just posted a link to that. Looks nice
Kermit
Re: 2014 Z1000
Post by Kermit »
Phil wrote:But I do like the new S1000R BMW
Fan of the S1000RR, but the net photos of 1000R makes it look its hit a wall; than paying for the privilege of fairing removal, minus 40 hp; but hey will give you some clip on's.
Hope it looks better in the flesh.
Cshat
Re: 2014 Z1000
Post by Cshat »
Now kawasaki has 2 ugly naked bikes, z800 and z1000. Glad I got the 2010 z750. Shits all over both models
I love all bikes, but the naked ones get me going
Re: 2014 Z1000
Umm the 1000r is cheaper isn't it? The s1000r is a fully optioned or nothing price point.
Oh and most reviews say you can't really notice power loss in the s1000r compared to the rr
Re: 2014 Z1000
Because the bulk of the RR's power is at almost red line. Useless on a naked "road bike"
vanrootn
Re: 2014 Z1000
Post by vanrootn »
Saw a 2014 zed at the dealership a couple of days ago... I think it looks better in the photos! Really not a huge fan.
s man
Re: 2014 Z1000
Post by s man »
I like it, be different I say, we can all ride safe boring bikes, but only a few have to guts to be different..
