Question for 2 stroke fans......
kawadave
Re: Question for 2 stroke fans......
Post by kawadave »
Strika wrote:
Or, as Gos says, the choke circuit might be screwed? However, you said you rode it, so I assume you had backed of the choke by then?? :)
Here's today's findings.:roll:
Have traced the problem to the choke on the carb in question.
This has nothing to do with adjustment as as such.....adjusted the three chokes as per manual with 1/8" free play at carb and the synced the carbs using a Uni-Syn.
I've found if I place my finger over the hole with the choke plunger completely removed...she starts to fire, popping as it should.
Have made sure all the choke orifices are clear from blockage.
Don't know what to do from hereon....what do you guys think?
I'm thinking its time to source another carb.......... :D
2013 Motogp tipping champ.
83 GPZ 750 Turbo
78 Z1R 1000
80 Z1R Mk11
07 ZRX 1200r
83 GSX1000sd Katana
Stuzrx
Post by Stuzrx »
OK.....it's a bummer of a thing to suggest,but. I would replace to the troubled carb,after checking fuel flow through the new tap and the carb,all the original "old" parts. Mount the carb to the right hand outside cylinder (it sits higher and gives more room to move around) and don't move to any other,it's obviously not necessary to do so. Pull the iridium plugs out,put "normal" plugs in.
Start the bastard as per normal process.If the truobled carb is "working"ok, you now have a good starting point.....Replacing a part at a time and testing each piece with a starting procedure,you should be able to trace the problem within the carb. Don't groan too much, it does'nt actually take that long to do.
Really!!
Lets see what happens.
kawadave wrote:.......Surprisingly enough it starts easy and idles well.
But when I took it for a test ride it was boggin down badly at low to mid revs....which also suggests it is a pilot jet problem,yes?....
this seems weird.......if it starts and idles well, it would have to be firing on all 3. Bogging down at low to mid does sound like a plug has died ? The pilot jet only works on the low-speed circuit - idle to about 1/8 throttle.
Low to mid is controlled a lot more by the needle.....here is a good chart which explains it better than I can :lol:
I started this post well before lunch :lol: and can see that you might have found something with the choke actuator on the dud carb ? Time to source a new carb methinks......
kawadave
Post by kawadave »
Stu... as mentioned in my original post...have swapped the dud carb on all 3 cylinders with the same result.
Also swapped out other components from the good carbs to the dud one.
On Gos's recommendation checked the fuel flow and made sure the float needle was shutting down correctly..."tick".
Plugs are not the problem..
The reason I tracked it back to the choke was......
Started the bike...manually pulled the enrichment (choke) cable on 1 of the good carbs...result = bike stalled.
Repeated the process on the other good carb...result = bike stalled.
Repeated the process on the dud carb....result = nothing.
Mysterious as it may seem....I'm on the hunt for a replacement carb.
Might have a talk with Kev...maybe he will be kind enough to lend me one of his for a trial ?
83 GPZ 750 Turbo
78 Z1R 1000
80 Z1R Mk11
07 ZRX 1200r
83 GSX1000sd Katana
born green
Post by born green »
The answers pretty simple really.................. fark the two strokers, they went out with noah.........
Four all the way........... let the crap start............ :shock: :shock:
96 ZX7R roady
95 tickford XR6,
Stuzrx
Post by Stuzrx »
born green wrote:The answers pretty simple really.................. fark the two strokers, they went out with noah.........
HaHaHA!!!.....took long enuf four this to be said!! I'm veeery disappointed hat36.gif
born green
Mate, u live in 120Ks east of home of poofter pete... its takes a wee while to get there :lol: :lol:
96 ZX7R roady
95 tickford XR6,
Stuzrx
Post by Stuzrx »
kawadave wrote:Stu... as mentioned in my original post...have swapped the dud carb on all 3 cylinders with the same result.
I don't think you understand what I'm proposing Dave. But anyway,you appear to have chucked the towel into
the too hard basket. Hope you find a good carb!! :cheesy:
Stuzrx
Post by Stuzrx »
Assume that supposed to mean something......But fraid it's over mah kerntry boyah head..
born green
Mate, u live in 120Ks east of home of poofter pete... its takes a wee while to get there :lol: :lol:[/quote]
Assume that supposed to mean something......But fraid it's over mah kerntry boyah head..[/quote][/quote]
Just takin the piss... i used to live in tenterfield........ and allways took offence to that sign comin into town.. about the home of peter allen.......... someone who shall remain nameless painted it... home of poofter pete...... anyway, back on subject.... 2strokes went out with noah.......... sorry
96 ZX7R roady
95 tickford XR6,
dickfaber
Post by dickfaber »
heres the real problem!
metrosexual men
male hair stylists
skin care for 'men'
the size of balls in todays youth must be shrinking, so they had to ban the 2 strokes, no one left has the balls to ride them!
born green
[quote="dickfaber"]heres the real problem!
metrosexual men
male hair stylists
skin care for 'men'
Haha must be close.... i stopped riding em in 87.......... but i got no balls left :lol: :lol:
96 ZX7R roady
95 tickford XR6,
kawadave
Post by kawadave »
Stuzrx wrote:OK.....it's a bummer of a thing to suggest,but. I would replace to the troubled carb
I'm hearen ya mate.... ;)
83 GPZ 750 Turbo
78 Z1R 1000
80 Z1R Mk11
07 ZRX 1200r
83 GSX1000sd Katana
Stuzrx
Post by Stuzrx »
born green wrote:Mate, u live in 120Ks east of home of poofter pete... its takes a wee while to get there :lol: :lol:
Just takin the piss... i used to live in tenterfield........ and allways took offence to that sign comin into town.. about the home of peter allen.......... someone who shall remain nameless painted it... home of poofter pete...... anyway, back on subject.... 2strokes went out with noah.......... sorry[/quote]
The appologies are mine mate....120k's east + pofta pete should've spelt it out pretty clearly. Just in case you may have forgotten,the hoon upto and down from the tenterfield is still quite invigorating!!
Stuzrx
Post by Stuzrx »
Just buy more strokers Dave......she'll be right!! :lol: :lol: :lol:
