nah that's my Motard after a spider monkey ride.blackster wrote:That's a decent effort! After the supers?
My rear isn't that worn, that leaves rider input.
The crim is stripped down for a valve and cam chain adjust/check
I haven't fiddled with the spring pre load, rebound damper force & compression damping force adjusters. According to OEM specs the bike is set up for a 68kg rider; I'm not that far off from, well perhaps alot more when having one to many liquid lunches and not hitting the gym.Nelso wrote:If your rear tyre is spinning up I'd say either your suspension, riding technique, or tyre pressures need adjusting.
Like this?hoffy wrote:just stick it in...see what happens..
blackster wrote:I haven't fiddled with the spring pre load, rebound damper force & compression damping force adjusters. According to OEM specs the bike is set up for a 68kg rider; I'm not that far off from, well perhaps alot more when having one to many liquid lunches and not hitting the gym.Nelso wrote:If your rear tyre is spinning up I'd say either your suspension, riding technique, or tyre pressures need adjusting.
What pressures would you run on the road with 120/70ZR17 & 180/55ZR17?
I fully agree with Nelso on this one...I haven't fiddled with the spring pre load, rebound damper force & compression damping force adjusters. According to OEM specs the bike is set up for a 68kg rider; I'm not that far off from, well perhaps alot more when having one to many liquid lunches and not hitting the gym.
