ZRX Misfiring problem update - Aaaaargh!!!
- Glen
Re: ZRX Misfiring problem update - still no banga banga
At this point if someone said to wave a dead rat over it three times then stick it in the tank and chant kumbya while sucking red jellybeans in the corner of the garage I'd try it.
Thanks mate. I'll give that a crack when I get it back
- Strika
Just a thought.... have you checked the pressure release valve on the tank cap? Or have you had it running from an external fuel source with same result? Just a simple thing, so worth checking.
- Six Addict
- Pinchy
- Bike: Ducati
hey glen, how about you try wave a dead rat over it three times then stick it in the tank and chant kumbya while sucking red jellybeans in the corner of the garage
- Jonno
- Mobile Chicane
Nah dont use red jellybeans the trade secret is M&M's
- BlackRabbit
Put the old exhaust back on and give that a go. Have you checked for any vacuum leaks also?
I am here: http://maps.google.com/maps?ll=-37.618954,145.095094
10 ZX10 Melbourne
- tim
Whichever you choose just make sure you tell me when you're goin to do it al I can record and post it up here.Jonno wrote:Nah dont use red jellybeans the trade secret is M&M's
In all seriousness If you're going to donut this weekend let me know and I'll see if I can hoot around to give you a hand (and record of course)
- tim
Bloody autocorrect
should be 'do it' not donut, and 'shoot' not hoot
- Glen
Thanks guys. I'm going to pick it upon Tuesday and then I'll go over everything that everyone has posted up and see if one of them works. My gut tells me it's something stupid as we've eliminated the major stuff I think. I'm also going to stick a stock air filter back in it and see if that makes a diff.
fire her up in the dark and see if there is any sparks jumping around your plugs ,coils,leads ect
just fucking hit it with a hammer Glenno...
- Glen
Re: ZRX Misfiring problem update - maybe closer
Well guess what we've found. The twat who worked on the bike for the previous owner in an attempt to presumably make it run better did a few dodgeys.
We'd already found the needles in it were ridiculous. They were actually stepped in about half way down, the only time Craig had seen these previously were on a TZ Yamaha, so it went from stupidly lean to stupidly rich in an instant, however that didn't fix the miss.
When I got it it had a bodgey exhaust on it with a plate welded on the link pipe after it had been shortened, so I flicked that for the Muzzy.
Now we've just found the snorkel on the side of the airbox is missing so there's just a dirty great hole in the airbox. I found one at Vic Motorcycle wreckers for $25 so it should be here tomorrow. We'll give that a go and hopefully that might be it. I'm also punting the K and N filter in favour of the stocker as well just to get the airbox back to dead standard. On the ZRXOA forum the guru's (in particular the guru of all guru's) all reckon its something to do with the airbox so I'm hoping they're right. This could also explain why it suddenly appeared when I put the Muzzy system on.
I'll put an update in tomorrow with the results.
Some people just shouldn't be allowed to play with motorbicycles.
Don't worry Hoff, if this doesn't work I'll be coming round for the hammer.
I know your electrics aren't Lucas, but if you have let the smoke out see if you can find one of these it might help?Strika wrote:Also, don't forget that all electrickery is operated by smoke. Check to make sure there is still smoke in the CDI. If there is no smoke left in it, then it's most likely that it's escaped and the CDI won't work anymore.
Tony
I have become race...
- MAXUMIS
Just out to help but if you have a miss on the dyno it can alter the 'real' AFR's buy a long way,all i mean is the AFR's can look rich or vise verser depending on the problem.When you find the prob as it can be hard to find without actualy seening what is happening your best bet is to get it run up again just to make shore your AFR's are write.
life starts at 200 kph!
- Glen
Yeah absolutely mate that's the plan. The bike is still sitting on the Dyno at C and M so we'll plug the hole in the airbox tomorrow and run it and see if that does it. If not then I'll take it home and just keep fiddling till I find it. Once I do then it'll be straight back on the Dyno again.MAXUMIS wrote:Just out to help but if you have a miss on the dyno it can alter the 'real' AFR's buy a long way,all i mean is the AFR's can look rich or vise verser depending on the problem.When you find the prob as it can be hard to find without actualy seening what is happening your best bet is to get it run up again just to make shore your AFR's are write.
Fingers crossed for tomorrow.
- Glen
You think I'm stoopid. I'm not falling for that.Bogan wrote:I know your electrics aren't Lucas, but if you have let the smoke out see if you can find one of these it might help?Strika wrote:Also, don't forget that all electrickery is operated by smoke. Check to make sure there is still smoke in the CDI. If there is no smoke left in it, then it's most likely that it's escaped and the CDI won't work anymore.
I looked it up on the interwebs and I need special Kawasaki smoke, my facebook friend told me so.
