Yoshi slip on 250r back fire
Moderator: Six Addict
- P4nza
- Bike: Don't have one
Re: Yoshi slip on 250r back fire
My SD pipe didnt come with that stuff either and doesnt leak but as Six Addict says it shouldnt be a problem
Team Crashed 2010
Team Crashed 2010
- philbo
- State: Western Australia
24,000km with a yoshi from day one and never had a problem. If you got the balls you can get the bike to shoot flames
did this the last day i had the bike. little to say my hearing is a little bit more shot now
DONT LET FEAR HOLD YOU BACK
Storm-010 white zx6r
- pertness
- Bike: ER6
Similar thing happened with my yoshi on my ER, I plugged the PAIR valves. And it doesn't backfire on start up and RARELY on deceleration.
http://shanetp.110mb.com/Pair%20Valve.pdf for the ER6 and 650R..
Hope it helps.
Hope it helps.
PERTNESS!
- philbo
it sounds the best when its popping and farting
Update: Its back on ! Been on for about two weeks and in that time its only backfired twice and its been kind enough to only do it in the arvo startup and not in the morning.I used a bit of exhaust tape around the pipe one time around and slid the slip on over the top of it(there was a small difference in diameter between the pipe and slip on,enough that it wont tighten right up solid without the the tape)
