Tech spec or stomp grip?
Re: Tech spec or stomp grip?
:kuda: Buy both, put one on each side and see which way you slip under braking. Then you can tell us which is best!
I wish they did it for the new zed thou.... :(
dilligaf
Post by dilligaf »
hoffy V2.0 wrote:I wish they did it for the new zed thou.... :(
get the techspec sheets and cut your own.
http://www.techspec-usa.com/products/gs_misc.html
Id prefer custom fit..
Are there any other types of this sorta stuff? Maybe from us...?
I mean techspec only does a few kawi models..
just dont get the stomp, it looks gay as a handbag.
but seriously, do you really need it on a roady?? :lol:
Team Monster
Post by Disco »
hoffy V2.0 wrote:Are there any other types of this sorta stuff? Maybe from us...?
When I bought mine for the old 6 it had 4 peice's 2 off them I didn't use you can have them if you want....Oh and it's snakeskin type...
EDU
Post by EDU »
Same, just put mine on the other day and gave the 2 smaller pieces to a friend. He tried it on his Blade '09 and it fit really well!
Just one thing I forgot to say and that I haven't seen anyone else comment on... I had the stomp on my previous bike and it wasn't black version so I could see ALL the bubbles trapped inside. My solution was to poke them with a needle and push the air out. Worked a treat.
On the Techspech you obviously can't see any air trapped but to be honest I think it sticks better to the tank so there might be less of it too.
Team Monster
Post by Disco »
Wattie wrote:just dont get the stomp, it looks gay as a handbag.
I'm confused are you saying he should get it? :? :lol:
With the sides and tank protector bir its a good functional alternative to a gcc cover..
ibanezboy21
Post by ibanezboy21 »
get the tech spec, looks so much sexier than the stomp grips
the stomp grips look cheap and gross
Icey_Cold
Post by Icey_Cold »
hey ibanezboy21,
is that the snakeskin grip? I've got a black zx10r trying to decide which one i want...
stetto
Post by stetto »
Ive used both, they both work great but the tech spec looks better and doesn't rough up your leathers like the stompgrip
Really? I found it was the opposite.
Whilst the tankgrip looked the part it tore my leathers where the stomp grip on the 6r hasn't.
EDU
Post by EDU »
None of them roughed my leathers and I had them both... but IMO the techspec looks better and it doesn't 'move' when the bike is really hot. Also my stompgrips let go after a while... started peeling from one of the corners and next thing I knew that whole thing was useless. And yes, I did clean the tank and followed ALL the instructions and tips I could find. Hair dryer and whatnot...
