zx12r zx10r comparison
Re: zx12r zx10r comparison
different dyno's mate - I reckon on Tex's dyno, the MFP12 would be up closer to yours......this dyno print-out was from about 3 years ago, prior to some of the new mods.....and I think the mapping could do with a re-jig anyway, as the map that came with the PCIII was for Groggles old 12, I have the same exhaust and filters, but he didn't have the secondary flies removed - mine is probably running a bit lean up top, hence the lower figure compared to yours and Hoffy's....
but over 200hp really interests me...... :kuda: - the US forums have a few punters with 12's that run up over 200, and they have all had a *lot* of work done to get this sort of power....
shinnynoggon
Post by shinnynoggon »
when i was buying the 12r i checked up on the specs and read the 05 model road test from australian motorcycle and from standard the 05 had 187 hp at the crank :shock: ;) :D i still have the article gos ;) after reading this i changed my mind from the 2000 rsv mille to the barge ;) :kuda:
zx12r 05 roady "black betty"
zx12r 00 roady "midori"
zx9r 99 tracky "weed"
