Powder coating in Sydney
timmyrocks
Re: Powder coating in Sydney
Post by timmyrocks »
in relation to making sure they DONT paint the disk surfaces, that is totally correct and id remove all paint/powder coat as the thickness of this will cause you disc to be offcentre and also it cannot be done 100% even so it could cause run out of your disc ;)
Team Crash "09"
WR125 2004 Husqvarna :P
roastdinajima
Post by roastdinajima »
We have a heatproof tape that can handle the temprature it costs about $40 a roll :shock: don't use masking tape if you're having things powdercoated its a right pain in the arse to remove it when its been cooked on!
roastdinajima wrote: don't use masking tape if you're having things powdercoated its a right pain in the arse to remove it when its been cooked on!
:lol: found that out the hard way once... every sleeve end & bolt hole on a frame, spent hours with a razor blade cleaning up the mess :x
jet-pilot
Post by jet-pilot »
two pac and with polished edge $220 a rim here in the west. rims were soda blasted first. the rims were handed over bare.
http://www.warpspeed.net.au
http://www.ratedrparts.com
http://www.aussiestreetbikes.com referred by jet-pilot
FACEBOOK ( jet-pilot )
