could probably use a new cam chain, do the clearances, and a good balance.
Just some thoughts....
*updated vid** Track Bike.. (95 ZX6R) Close to being burnt!
Re: *updated vid** Track Bike.. (95 ZX6R) Close to being burnt!
- swabio-ACT
Clearances were done before i moved to syd.... as was the carb balance....Gosling1 wrote:could probably use a new cam chain, do the clearances, and a good balance.
Should add, that vid was done in an underground carpark that is uber echo'ey etc
- timmyrocks
mate, sounded ok, maby a bit hesitant on the throttle,,,
warm her right up, kill it then try and restart, if its reluctant to start while hot your carbs may be outa sync or even valve clearances, but seeing as you get them done recently. Id clean the fuel tank, drain carbs bowls till freah fuel comes outa them, spray some carby cleaner ontop of the carbs while running, clean or change air filter, and oil and filter and she'll be right hehe.
being sitting around for a while it may just need a good thrashing,,,, track day
Tim
Team Crash "09"
WR125 2004 Husqvarna
Team Crash "09"
- DaBigfella
- Bike: GTR
Only new to the game so don't hate me for this, but the electric display you have there, what is it called and are they hard to install??
- swabio-ACT
it is the Veypor VR2, and they are pretty easy to installDaBigfella wrote:Only new to the game so don't hate me for this, but the electric display you have there, what is it called and are they hard to install??
