Blue14 wrote:Ok have checked from top to bottom. I think it maybe the speedo head ?? It seemed to have almost gone until i touched the knob that you use to reset the trip metre.. Maybe its lose in there or something, any ideas ??
Blue, mate, there is a (very) small screw, phillips head I think, that holds the reset knob on the shaft. If tightening that doesnt help, take the back cover off the speedo/tach assembly (after removing the reset knob) and replace the small dust sealing grommet that sits around the reset knob shaft. A little Vas (why is it always some Vas? Is there a kinky kinda trend here?) helps get the grommet in and stuff. While yer in the back of the instrument cluster, check for other loose stuff, like lamp holders and stuff. It's gotta be in there somewhere!!! Cheers and best of luck. Woof......
scottyZRX wrote:I took the four small washer-spacers out (the ones that line the rubber grommets) and shortened them by about 0.5 mill or so and screwed them back in with a little vaseline to help the neoprene out: buzz gone!
I second this motion...
I just did the same & it fixed it a treat.[/quote]
Sweet........Woof.....
Strika wrote:You big prick! You only come in here to get your problems fixed! You never contribute anymore! So obviously we are just a resource for you now! Plus...you don't return phone calls! You're obviously too busy with ya netnanny buddies to worry about us lot now! So why don't ya go and get a big black one up ya!
I love you too marty.. And i dont remember any call from you mate ..
Left a message on your mobile before christmas ya knob!
