2008 Z1000 compared to a 2003/04?
deafwish
Re: 2008 Z1000 compared to a 2003/04?
Post by deafwish »
Hey Wattie,
What do you miss about the Zed, compared to the ZX10R?
p.s. There is a ZX10R on Riderforums that has been converted to look like a Zed! :P 8)
i miss the pillioning capability.
the green and polished lip wheels.
the ease of staying under the speed limit.
oh and the fact that no one expected it to be as quick as it was when ridden correctly
deafwish
Post by deafwish »
THE best compromise! :D
Only if Kawasaki actually made this... :(
ProblemChild
Post by ProblemChild »
Wattie wrote:i miss the pillioning capability.
dont worry mate , the wheels still look awesome , as does the rest of it :D , oh yeah i have a 4-1 on it with no powercomander & it goes like shit off a shovel ;)
dirty,mean&mighty unclean,
Im a wanted man
ttc
Team Black
Post by ttc »
pc/wattie.. did by any chance you have a power dyno run that showed the air fuel mixture? The only reason I ask is that mine leans out really badly without the pc
deafwish wrote:THE best compromise! :D
WE HAVE WOOD :shock:
ttc wrote:pc/wattie.. did by any chance you have a power dyno run that showed the air fuel mixture? The only reason I ask is that mine leans out really badly without the pc
i may have the dyno readout here somewhere. but that was with stock pipes. :?
im still suss on the whole kleen system stuffing up the dyno readouts. afetr all is is putting oxygen into the exhaust gasses after it exits the cylinder.
deafwish
Post by deafwish »
Wattie wrote:im still suss on the whole kleen system stuffing up the dyno readouts. afetr all is is putting oxygen into the exhaust gasses after it exits the cylinder.
Any good dyno operator will block the main KLEEN hose from the airbox prior to the dyno run.
IIRC, the KLEEN only injects air when the throttle shuts.
