05 ZX10R Brakes - Brembo Master Cylinder
Re: 05 ZX10R Brakes - Brembo Master Cylinder
Yeah Im keen to know where to get em too, my set up looks dodgy as
Here ya go Matt .........Brembo 19x18 Forged Brake Master Cylinder with Standard Lever
http://www.baysideperformance.com/index ... ts_id=6558" target="_blank
FIY the 19/20 one has 2mm more lever action but the 19/18 seems ok
Troy Pearson
Rob if you send that info to us via this reply it would be great! No rush though, I wont be home until early April but I would like to order it so I have when I do get home!
Cheers Troy.
Cheers Troy.
Which reply? just look up this page when you get back failing a site crashTroy Pearson wrote:Rob if you send that info to us via this reply it would be great! No rush though, I wont be home until early April but I would like to order it so I have when I do get home!
Cheers Troy.
Cheers Troy.
Troy Pearson
Thanks Rob, lucky I don't ride with my eyes closed!!
I was looking at around $400 AUD with resovoir, washers, double banjo and shipping.
Troy Pearson wrote:Thanks Rob, lucky I don't ride with my eyes closed!!
Yep easy get it for that, just make sure you order the double banjo (with pressure switch if needed) & remind them I orderd a double & they sent me a single ... must be something in the Canadian water
Troy Pearson
I just did a little research not that I don't trust you Rob. I just wanted to know if I was saving much money getting the Master Cyl from Canadiiiaaa!!
I called Gowanloch Ducati as they are stockists and they quoted me $675 for just the 18 x 20 Master Cyl alone!!
So if anyone else reads this again, go the Canadian route for your Brembo needs. I did an online estimate including shipping and it came to $411AUD.
Thanks again Rob,
Troy
Thanks again Rob,
Troy
$411 im sure mine was just over $300 landed but the paperwork is with my accountant so I cant checkTroy Pearson wrote:I just did a little research not that I don't trust you Rob. I just wanted to know if I was saving much money getting the Master Cyl from Canadiiiaaa!!
Thanks again Rob,
Troy
Troy there are a few different types of Brembo Radial MC's & it could be that gowies has the more expensive one's
Mine is Cast & I think the GP race ones are Billet but dont quote me on it
I looked at about 4-5 sites before ordering from Canada there was also one place in the states that was cheeper but looked suss so Canada it was
http://www.mcnews.com.au/testing/Kawasa ... /Page4.htm
read paragraph 5...
this guy must be like pedrosa's size...
using the stock brakes on setting 5
best brakes ever, what a dipshit!
read paragraph 5...
WTF close to the bars
he was probably riding in the rain & didnt even use them
robracer wrote:WTF close to the barshe was probably riding in the rain & didnt even use them
or didnt even go to the realease, and copped a pocketfull of goodies for a good story.
there is no way he was riding the same bike that was sold in the shops
- browserzx10
Yep i got the brembo mater cylinder last year. Best thing i have ever done, the lever just doesnt fade at all anymore. I was able to use the standard resivior as the hose i got just went over the fitting on it. Must have been lucky i guess.
I used to have a grip on life but it sliped
Well after finaly getting a chance to test out the new MC the verdict is...... Brilliant! there was no fade or lever pulling back to the bar so Im sold
+ now using blue dot 4 brake fluid from Bursons $7.00 for 500ml that will be changed twice a year
great value!
