10 on the Dyno today
Re: 10 on the Dyno today
different brands of dyno also vary, the dyno day wattie was reffering to was on a dynodynamics dyno, which usually read lower than a dynojet dyno.......thats the general rule as far as i've been told by several people. add in weather etc etc......
but as has been said previously, just make sure you use the same dyno to compare if you do mods.....and "i've got more Hp than you" type discussions are only for bragging rights in the pub IMHO, both my bikes are waaaay down on 160 hp but still go fast enough for me.
BTW, i'd like to see the torque and revs as well, thats of more importance ;)
daffy67
Post by daffy67 »
Torque and revs was on the rear of the readout.
157.9 was reached @12500rpm, max torque was @8455rpm, the readings lists 'tractive lb' 451.
Blue '07 ZX-10
matchtheclown
Post by matchtheclown »
I have micron cans but apart from that it's stock.
I'd put it down to dyno difference's too.
IsleofNinja
Post by IsleofNinja »
Hi all.
Good to see some actual printouts and facts rather than the usual beer inspired B/S :roll:
Sorta sad I didn't do a bog stock run with mine..Will be interesting to see how we go when I get the PC USBIII tuned properly on the dyno rather than a generic map as atm.
06 ZX10r , 95 ZX9r
07 FXST
