Coolant Boiling
- Strika
Mike the coolant reservoir doesn't form part of the pressurised cooling system. The Rad cap is where the pressure is held. The catch tank is only to catch the fluid as it heats up and expands, then as it cools it sucks the coolant back into the rad. Changing the bottle shouldn't fix the prob. My guess is either the rad cap is leaking or not holding pressure, or a head gasket is on it's way out.photomike666 wrote:The crack and leak is your problem.
When the system is pressurised, it raises the boiling point of the water (from 100deg to about 120). The liquid expands as it boils, and under pressure there is no room to expand. As you have a crack it allows the expansion at the normal temp (100 deg) and so the liquid boils. Fix the crack, fix the boiling problem, as most engines are designed to run around the 100+ mark.
- Frank
Maybe it shouldn't fix the problem Marty, but it did exactly that when I had exactly the same problem, as I said before the reason the bike over heats is, as the coolant get hot and expands in to the overflow bottle, it leaks out of the crack, thus when the bike cools down it cant retrieve the coolant from the overflow bottle, like mine this eventually leads to the bike having little or no coolant, sooo the bike overheats.Strika wrote:Mike the coolant reservoir doesn't form part of the pressurised cooling system. The Rad cap is where the pressure is held. The catch tank is only to catch the fluid as it heats up and expands, then as it cools it sucks the coolant back into the rad. Changing the bottle shouldn't fix the prob. My guess is either the rad cap is leaking or not holding pressure, or a head gasket is on it's way out.photomike666 wrote:The crack and leak is your problem.
Once I put the new bottle in the bike hasn't had one drama even sitting at lights for ages on a 33deg+ day
GO THE BLUES
Life time member of PETA:-
Member of SRT
1998 Kawasaki ZX9R Track Bike
2014 Nissan Navara
Member of SRT
2014 Nissan Navara
- Lone Wolf
- Bike: ZX7R
I think you're right mate. When I changed the bottles over and did the whole flush/refill thing, there was not a drop of liquid in either the radiator or the overflow bottle. Very lucky not to do a head gasket I think
It had dropped to the low mark once the return trip was over, and seems to have settled there, but it still shits me that it seems to have lost coolant, without any obvious signs of leaks, splits, holes in the radiator, loose hoses etc......
- Slow and wobbly
- Bike: Scooter
My vote, along with strika, is the rad cap. If it doesnt seal properly it allows the coolant to escape before pressurising thus lowering the boiling point as PM touched on. If the system does not presurise then the boiling point is normal ( 100 deg ) and the thermos dont come on until 102 (?) Also in agreement with the cracked bottle not holding enough fluid for the system to draw upon when cooling.
Gos if the twelve has settled at a happy level now is it possible that when it was last drained and refilled ( pre PI ? ) there could have been an air lock?
