Yeah, I was hoping to pinpoint the actual problem before taking it somewhere..... Some mechanics will shaft you because they spend 3 hours trying to figure out what is actually wrong.... Usually when I go to a mechanic I like to know exactly what is wrong before I take it...Smitty wrote:thats the whole point of a regulatorrocketrod wrote:Yes you should get max charge at about 4000rpm.Your charge going into the battery will depend on how healthy the battery is.
it allows a maximum charge depending on the state of the battery
up to a point...the charge going in will NOT get higher the faster the alternator turns over (becoz of engine revs)
The regulator works to stop overcharging ..and boiling the battery
good idea....becoz there are lots of things that can be the cause.If you are not sure what you are doing i suggest you take it to an auto elec as you could end up doing more damage.
the rectifier in the alternator could be acting up
the regulator could be stuck shut or open or shorting
there could be internal resistance in wiring
get someone who know whats what
hth
Battery charging
- Stereo
- Smitty
lectricity mateStereo wrote: Yeah, I was hoping to pinpoint the actual problem before taking it somewhere..... Some mechanics will shaft you because they spend 3 hours trying to figure out what is actually wrong.... Usually when I go to a mechanic I like to know exactly what is wrong before I take it...
can drive a man to drink
even the most qualified guy with a meter can spend time on something like
this..especially if you have to start checking the windings in the alternator
or output levels at certain revs
- mfzx6r
Hey StereoStereo wrote:How do you check the voltage before the reg-rect and what should it read?
have you got a copy of the workshop manual ???
in my 00-02 zx6r one its all there step by step in chapter 15 how to check all the charging system
Mario
'01 zx6r
klx300r
Part of the "Fookarwe" tribe
'01 zx6r
klx300r
- Stereo
Its the spewzukimfzx6r wrote:Hey StereoStereo wrote:How do you check the voltage before the reg-rect and what should it read?
amen to that - cheap chargers don't have spike protection (usually), so any voltage 'spikes' through your charger have the potential to fry your electrics .....Rossi wrote:BladeBoy wrote:Answer: In Place.
WRONG![]()
Stereo your bike has an ECU system fitted and most home / readily available chargers have been known to "spike" these delicacate electronics. I always disconnect the earth lead when charging a battery
surely there is a downloadable manual *somewhere* out there for this model Spewzie ?? It will have all the specifications for checking the alternator outputs, etc. Without it, you are just flying in the dark......
SocialSecurity
- State: Western Australia
- Stereo
Wasnt me that asked that............ I never charge with my battery in place.....Rossi wrote:BladeBoy wrote:Answer: In Place.
WRONG![]()
- ducati_paul
I thought I was wrong once but I was mistaken, anyway..been charging bike/car batteries for 30 years, no problems so far, seeing you could not buy a charger that has as many spikes than your normal electrical charging system that comes with your bike, I think you will be right. ECU or not.ducati_paul wrote:I think I confused things by asking about charging in place, and Bladeboy answered meso I should disconnect the leads? this is for my ZZR600 trackbike
- javaman
- Bike: GPz900
Charging with Battery connected in place is OK, i know that as a FACT
Of course, don't try to turn the ignition on
http://GPZninja.blogspot.com/
