deafwish wrote:Might have to get you to help me do this one......Wattie wrote:the kleen system is easy to fix, i cut the hose and stuck a tap off a sprinkler system in it, so i can open and shut it![]()
makes a difference to the noise, nothing to performance..
stops popping and backfiring.
its easy, crouch down the left hand side of ya bike, look up under the tank, there is a black rubber hose about 2cm in diameter, runs from airbox forward to a T and then each side goes into the top of the motor.
all i did was cut the long part of the hose, and put a tap in it, (from bunnings) and close it off. you can block it anyway you like.
