not true follow the cable on the 636 it goes to the throttle boddies to a separate set of butterflies that block off the air intake during cold starts
Fast idle/choke
blackninja
SocialSecurity
- State: Western Australia
blackninja
the butterflies block off cold air coming in through the air box so that the engine just burns fuel just like any choke does when the engine warms up it can convert the raw fuel into gas so the choke can be let off the butterflies open lletting in air so the engine can run a fuel vapour air mixture
03 zx6r blackninja
回転日本語私は実際にそう考える
回転日本語私は実際にそう考える
SocialSecurity
click on this link, and look for the word 'choke'... explains how motorcycle enrincheners work, as well as normal car carby chokes...
http://www.roadkill.com/~davet/moto/carb.monologue.html
on an EFI setup, the only place fuel goes into the engine is the injectors
SocialSecurity
why dont you give the fast idle lever a shot, if the bike magically starts coughing and spluttering with black stuff all over the pipe then you know it must actually be a choke lever.... if not, it will just idle higherWattie wrote:i think i'll just use the throttle and the idle screw
blackninja
SocialSecurity
blackninja
SocialSecurity
my kettle of fish doesnt have throttle bodies, it has carbys
the choke doesnt do anything to the butterflys, it opens up a port to take fuel straight out of the bowls (which is an enrichener not a choke)... its pretty good at fowling plugs too
so is your 636 an 02 or a 03+?
blackninja
SocialSecurity
blackninja
SocialSecurity
