Brake fluid
HemiDuty
Post by HemiDuty »
I was using the RBF600, but was STILL getting friggin fade, although not as bad as with cheaper fluids.
Anyway I am now going to try some ELF ($40+ per half litre :shock: ) racing fluid and see how that goes. If that doesn't work then it will be time to pull the brake system apart and swear at it a bit....
Will let you know how it went next week.
Drmsby Middleton
DC Racing
Extreme Motorsports
M2R
Castrol
ColourSmart Chroming
Hi Side Leathers
Teknic
Sidi
DID Racing Chain
Goodridge
Stretchy
Post by Stretchy »
RBF600 is the way to go.
The best brake upgrade you could do with stock calipers is a Brembo 19x20 Radial master cylinder. Unfugginbelivable difference.
HemiDuty wrote:I was using the RBF600, but was STILL getting friggin fade, although not as bad as with cheaper fluids.
Brake fade is caused by brakepad temperature though, not the cables/hydrolics ....... In fact dot4 and dot5 should be completely indifferent to what temparature it is (up to a couple of hundred degrees anyway)...
But yes.... Dot5 is the way to go.... someone else mentioned why earlier.... no moisture absorbsion.... (water compresses, causing worse braking)...
Minimum Specification Good Brand Min Spec
DRY WET
DOT 3 205 Deg C 140 Deg C
DOT 4 230 Deg C 155 Deg C
DOT 5 260 Deg C 180 Deg C
DOT 5.1 260 Deg C 180 Deg C
HemiDuty
Post by HemiDuty »
The thing I have heard about DOT 5 is that water can get into the system, and because it does not mix with it you end up with a water 'section' in the line, like a little bubble of water with fluid either side of it, and this water will of course compress when you go for the brakes.
Oh and my brake dramas are a combination of fade and lever travel, but the lever part is the worst of it for sure. I might swap master cyls with Stretchy on the weekend when he isn't looking and 'test' the radial jobbie.... :lol:
Drmsby Middleton
DC Racing
Extreme Motorsports
M2R
Castrol
Hi Side Leathers
Teknic
Sidi
DID Racing Chain
Goodridge
Steve_TLS
Post by Steve_TLS »
HemiDuty wrote:The thing I have heard about DOT 5 is that water can get into the system, and because it does not mix with it you end up with a water 'section' in the line, like a little bubble of water with fluid either side of it, and this water will of course compress when you go for the brakes.
It can be worse than that. The moisture / water pools at the bottom, it causes corrosion and when it gets hot it boils. A "wet" hydroscopic Dot 4 or 5.1 will have a better boiling point than a Silicone based DOT 5 with water separated and sitting in the system.
DOT5 Silicone fluid also feels "spongier" than the others.
(It's a fluid / system you'd want to refresh often)
Steve
HemiDuty
Post by HemiDuty »
Well the ELF stuff went better than the Motul.
So it looks like my racebike really does have expensive tastes..... :cry:
Drmsby Middleton
DC Racing
Extreme Motorsports
M2R
Castrol
Hi Side Leathers
Teknic
Sidi
DID Racing Chain
Goodridge
