Maximum weight ZX9R
Maximum weight ZX9R
Postby maraach » Mon May 19, 2008 1:17 pm
I was just wondering if anyone was aware of the maximum weight (as in rider + pillion + luggage) a zx9r (2000 model if it makes a difference) will handle?
maraach
Re: Maximum weight ZX9R
Postby Six Addict » Mon May 19, 2008 1:23 pm
sounds like you dont have your (ur for those people who can read text language) owners manual... it tells you the recommended maximum weight in the front section somewhere usually near all the specs like weight, engine capacity all that stuff...
my little 250 has a limit of 170 kegs so id reckon a 9 would be around 200... thats a semi educated guess...
Postby maraach » Mon May 19, 2008 1:36 pm
200kg would be great and its what im hoping for.
The owners manual inadvertantly got left at the Mechanics when he was stamping the log books. He is posting it out to me, but in the meantime im trying to work out if wife + bag full of stuff is a bad idea.... maybe the wife will have to stay home....
maraach
Postby Six Addict » Mon May 19, 2008 1:54 pm
i think you'll be sweet mate... if i bike like that isnt rated to tour two up then thats a major bummer
Postby cookeetree » Mon May 19, 2008 2:30 pm
Here's a PDF on the 2002 model (US).
It says 390lbs, which works out to around 177kg.
cookeetree
Bike: ZZR1100
Postby maraach » Mon May 19, 2008 3:35 pm
oh bother... was really hoping that wouldnt be the case. Kind of thought it might though. Thanks for the link.
maraach
Postby Gosling1 » Mon May 19, 2008 11:13 pm
200kg will be sweet - just bump the preload up a couple of turns before you load her up.....
ZX9's can tour with the best of them, and a 2-up package of rider, pillion and 20-30kg of Gearsack/tankbag luggage will not be a problem for the bike at all.
Postby maraach » Tue May 20, 2008 10:35 am
Gosling1 wrote:200kg will be sweet - just bump the preload up a couple of turns before you load her up.....
This is exactly what i wanted to hear :). In all reality, myself + wife both wearing full kit leathers is going to be right on the 177kg odd mark. As i wanted to carry that 20-30kg of stuff do some touring i began to worry that i might destroy the rear shock.
I'll put up the tyre pressure a couple of PSI and bump up the preload as suggested. I just dont want to ruin my rear shock.
maraach
Postby cookeetree » Tue May 20, 2008 12:25 pm
Have you thought about throwing an aftermarket shock in it?
cookeetree
Bike: ZZR1100
Postby maraach » Tue May 20, 2008 5:48 pm
crossed my mind but dont know anything about them... guess its time to hit google.
maraach
Postby zx899r » Tue May 20, 2008 6:06 pm
the ninja you got is still brand new you should'nt have any problems so get out there and put some kms on the clock :P
GO GREEN!
zx899r
Postby Gosling1 » Tue May 20, 2008 8:34 pm
maraach wrote:.......I'll put up the tyre pressure a couple of PSI and bump up the preload as suggested. I just dont want to ruin my rear shock......
actually tyre pressure was one thing I forgot to mention - you could add at least 5psi to normal settings, if you are fully loaded up for touring. Don't go over the manufacturers 'maximum' pressure ( eg 45psi), but if you normally run say 36-38 in the rear, bump it up to 41-43.
Postby maraach » Wed May 21, 2008 9:29 am
zx899r wrote:the ninja you got is still brand new you should'nt have any problems so get out there and put some kms on the clock :P
im dying too..... unfortunately i've had to work every weekend since i got the bike, so apart from brief night time rides (which arent much fun) i havent had a chance to really play with her yet.
Hence my sitting at work all day and day dreaming about being in the wide open country riding around for days..... Chances are when i finally get some free time i wont be on here asking questions anymore.
maraach
Postby BrisZX9R » Wed May 21, 2008 6:23 pm
I up'ed my 9's max weight with Racetech suspension.
I got all new internals for the forks.. and complete new rear shock.
They have different suspension for different weights and they provide a computer program to tell the mechanic how to set the front and back up exactly to your weight and height.. The rear spring is different colour for the different weights.
I got mine through my local bike shop. They got it sent over from the US and installed it all. Cost me around $700 i think. Now my '02 9r is riding sweet and I'm a biggin!... a real biggin!!
BrisZX9R
Return to ZX-R Older Model Discussion
