New ZX-7R owner
Re: New ZX-7R owner
Postby simatrik » Tue May 24, 2011 5:52 pm
I just went out and did it... assuming I was doing it correctly, everything seems smooth.
Is this to test the steering head bearings?
http://www.facebook.com/simatrik
1996 ZX-7R
simatrik
Re: New ZX-7R owner
Postby Lone Wolf » Tue May 24, 2011 6:08 pm
greenmeanie wrote:I bet that ain't the original speedo! ;) ......15000 & the rest.. :?
Was my first thought too.
ZX7R's do have a reputation for warped discs
Lone Wolf
Re: New ZX-7R owner
Postby simatrik » Tue May 24, 2011 7:32 pm
Is there a reason for this? Do you know if it's more of a case when using stock discs?
1996 ZX-7R
simatrik
Re: New ZX-7R owner
Postby greenmeanie » Wed May 25, 2011 7:02 am
Also check the overflow bottle(plastic bottle behind RHS fairing) as they tend to crack at the base. Is there radiator coolant in there ? :)
Glenn
2009 ZX10R
greenmeanie
Re: New ZX-7R owner
Postby simatrik » Wed May 25, 2011 7:58 am
greenmeanie wrote:Also check the overflow bottle(plastic bottle behind RHS fairing) as they tend to crack at the base. Is there radiator coolant in there ? :)
I got to have a good look at that the other day after the cap went walkabout. The bottle is fine but it beats me what happened to the cap!
1996 ZX-7R
simatrik
New ZX-7R owner
Postby Lone Wolf » Wed May 25, 2011 9:41 am
Re: the overflow bottle. If it does crack, buy new from Kawasaki. After replacing mine twice with bottles from wreckers I found out OEM ones cost only $10 more and the plastic is new, not having already been subjected to engine heat and less likely to crack easily
Lone Wolf
Re: New ZX-7R owner
Postby smithy5 » Wed May 25, 2011 11:30 am
Mine as well, at 15,000klms it should ride like a new bike .......
and it should read KAWASAKI's have a reputation for warped disc's.....
smithy5
Re: New ZX-7R owner
Postby Strika » Wed May 25, 2011 1:08 pm
If the front rotors are warped, then they may only shudder when hot, so spinning the wheel statically while cold may not replicate the warp. Either way, if the rotors are not lipped I would have them re flattened. The when you reinstall them, crush the spring washers slightly with a clamp or similiar. Not too much that they rattle, but enough to allow a little more movement. It reduces warpage.
The cracking as you pull up, is most likely just a little front pad movement. The 750 P's with the 6 potters did that. I doubt it's the steering head bearings.
Re: New ZX-7R owner
Postby simatrik » Wed May 25, 2011 2:52 pm
I know my old Daytona 955i used to have a cracking feeling when I stopped too, but it wasn't the bearings.
The bike is off to Brighton Kawasaki on Saturday, so I'll see how that goes.
Thanks very much for the replies! :-)
1996 ZX-7R
simatrik
Re: New ZX-7R owner
Postby simatrik » Tue May 31, 2011 4:57 pm
I picked the bike up this morning and the news is pretty good!
Head stem bearings are fine.
Speedo mounts are fixed, although the speedo reading is still out.
Discs are of a roadworthy thickness, but are warped.
All in all, they said it's a good bike and I shouldn't have any dramas with it. Time to go shopping for some discs I think!
1996 ZX-7R
simatrik
Re: New ZX-7R owner
Postby laidback » Tue May 31, 2011 5:11 pm
Good stuff mate...you must be happy. :kuda:
Re: New ZX-7R owner
Postby mick12 » Tue May 31, 2011 5:17 pm
another thing with the brakes if the bike has been sitting for some time it maybe a good idea to blow the pistons and replace the seals and compleatly change all the brake fluid front and rear the seals do perish this is usualy one of the first things i do after buying a used bike if you are replacing rotors do this at the same time
mick12
Previous
Return to ZX-R Older Model Discussion
