I live in the NT and a lot of my riding is between 100-130kph with the 130kph speed limit in the NT (just as well given the windsock effect above that speed on the Z750). I suspect that the bike has sufficient torque to maintain 100kph at around 4250rpm without affecting the bikes fuel consumption to any great extent.
In my attempt to reduce the engine speed a I have tried to find a 16 tooth front sprocket to suit the Z750 without any luck. The alternative is to go to a 40T or a 38T rear sprocket which I am reluctant to do given it would require shortening the chain which is a pain to undo if the resulting 15/40 or 15/38 ratio proves unsuitable.
Anyway - my question to the forum is - has anyone tried taller gearing than the standard 15/43 final drive ratio, and if so what was it like? Did it affect 1st gear performance very badly?
