98 zx9r vs 03 cbr954r
Postby I-K » Sun Aug 20, 2006 4:56 pm
Whenever you feel like turning this into a proper analytical discussion, you know where you can find me.
Until then, I'll make some space, so Kishy can get his broad shoulders through on his way to lick your arsehole some more...
I-K
Postby hammer » Sun Aug 20, 2006 5:06 pm
I-K wrote:Whenever you feel like turning this into a proper analytical discussion, you know where you can find me.
Just as soon as my microfiche machine and files turn up from demtel( Did you get steak knives with yours?) and I get all my old bike mags out from under my bed.
Sorry about Kishy to, I know you had a thing for him. Keep up your smooth ways he may turn for you.
Ride it like you hate it
hammer
Team Black
Postby I-K » Sun Aug 20, 2006 5:54 pm
Eh? You mean you need to look up stuff like this?
I-K
Postby SocialSecurity » Mon Aug 21, 2006 6:48 pm
how did i miss this thread :?
went for a ride today on my 98 ZX9R with the mrs on her 02 954RR
i can say with absolute certainty that the blade's chassis is leaps and bounds ahead.... however it should have been fitted with a steering damper from the factory (mrs has a bling scotts rotary damper on hers)... although i can appreciate my bike having absolutely no need for a damper... with the throttle about 3/4 open in first and the front wheel only just touching the tarmac it will headshake lightly but thats it... let go of the throttle and its business as usual.. hers was hella flighty before the damper but now its well.... perfect :oops: really feels like a 600, so easy to throw around
my suspension isnt set up 100% perfectly, but hers is just so much more compliant than mine... we went for a blast up to mt macedon and the roads are pretty bumpy and for the first time ever i just couldnt quite keep up with her :oops: :oops: :oops: :oops: tho my bike wasnt giving me any confidence to try to
hers is fairly stock with a BMC filter and micron slip on with no tuning... definately has a bit more go below about 4-5k, and perfect throttle response everywhere (actually a little bit too good when cracking the throttle open a touch from fully closed really upsets the bike, maybe a PC3 could help)...
in a straightline how ever my bike definately has more from 5k to redline, but mines not stock with a full akra system, +4 advancer, demeshed air filter, jetkit tuned to perfection by yours truely and +1 on the rear sprocket... tho my power is very linear, just gets stronger and stronger with the revs where hers has quite a punch down low thanks to the valve in the exhaust, the extra 55cc and EFI... which means her power is more usable out of corners... how ever on a long sweeper i feel i can put more power down on my bike than on hers, even kick the rear out a bit :wink: maybe its the long wheelbase helping out there
the 954 has a much better turning circle too :oops: and feels about 100kg lighter when your pushing it :oops:
hard to say which bike is comfier too, the short reach to the bars on the 954 is nice, long journeys i get some pain in my lower neck on the 9R... my seat is definately softer, but hers is a little wider...
in terms of vibrations mine seems a little more smoother..
certainly no trouble starting a bike with EFI either, almost had to push start the ninja today after sitting dormant since friday :roll: but the tune isnt quite perfect yet (choke rarely helps cold starts) and my battery is a bit average
oh and hers is only about 10% as crashed as mine :oops:
edit: forgot about the brakes.... once again, worlds apart... the discs on the 954 are huge, and with about 20kg less weight they really work well... where mine, even with braided lines i cant get a firm feeling from the lever no matter how much i bleed them... but to be fair, my discs desperately need to be machined, very glazed and burnt
Last edited by SocialSecurity on Mon Aug 21, 2006 8:29 pm, edited 1 time in total.
SocialSecurity
Postby Neka79 » Mon Aug 21, 2006 8:28 pm
ahh i love this place.... this blokey bloke stuff is keeping me on my toes....
as stated before..i rode the 01 zx9r...and 00 cbr929... and its common knowledge which one i bought (im not so popular anymore..mwahahaha)
but the blade is a nice bike...
Postby SocialSecurity » Mon Aug 21, 2006 8:43 pm
929's must be pretty weak if a 954 aint exactly scary :wink:
SocialSecurity
Postby SocialSecurity » Wed Aug 23, 2006 4:21 pm
oh one other thing....
for the same reasons that the 954 turns quicker than the 9R, the 9R is a traffic light demon in comparison :twisted: longer wheelbase makes getting off the line too easy on the 9R even with less power down low....
where the 954 is a tricky one to launch thanks to its ultra sensitive throttle and very light front end! the 9R just encourages you to push harder and harder, its wheelies are very friendly in comparison
SocialSecurity
Postby Strika » Wed Aug 23, 2006 4:42 pm
SocialSecurity wrote: its wheelies are very friendly in comparison
Yeah Dangerous Dave has dibs on hanging a few wheelies on the 9 once I get it registered!!! He likes a little extra length in the wheelbase. reckons it makes the 200 KPH stand ups a little less breezy, and a little smoother!!! :lol: Sick bastard he is!!!
Postby SocialSecurity » Wed Aug 23, 2006 5:27 pm
yeah, the shorter wheelbase bikes like blades, r1's, gixxers etc... can produce a lot in the way of unexpected wheelies...
where the 9R you have to want to wheelie to pop it up, but at the same time they can be fairly effortless 8)
wont really power wheelie in 2nd gear, occasionally pops up, or if i go over a crest with the throttle pinned and the revs in the sweet spot :shock: rolling the throttle on in first has some really wild accelleration if you control the throttle enough to keep the wheel on the ground... just absolutely launches forward :shock: its the busa of the sub litre class :wink:
SocialSecurity
Postby Johnnie5 » Wed Aug 23, 2006 10:42 pm
as mentioned the 954 has snatchy throttle
easily fixed with a PC
suspension , damper required
both easy fixed with a few hundred bucks spent on suspension setup, money that is quickly returned through longer tyre life besides the fact of a far better riding bike
a near new blade for the price of an old ZX9 , really a no brainer IMHO
at 40K your ZX9 is on the rapid downhill run to worth 2/5ths of fuckall in the general publics perception
Johnnie5
Postby SocialSecurity » Wed Aug 23, 2006 11:31 pm
954's are still going for 10-12k, perhaps the least depreciating, mass produced jap sports bike of the last 20 years
9R's are bargains...especially C-models :twisted:
SocialSecurity
Postby 99coconuts » Thu Aug 24, 2006 12:06 am
benny fixed his blade up and traded it because he couldn't get a bite on it. ended up getting $8000 for it :shock:
admittedly, if anyone knew what it had been through, they wouldn't go near it with a 10 foot pole, but as a testament to the honda tuffness, you wouldn't have known after the plastics were all replaced.
the honda tuffness.... well this bike got stacked more often than ben had ciggy breaks. the crash cage that he had on it had to be cut off it was that bent up, the plastics from top to toe were completely munted, he bent 2 12 bars and never had to replace the subframe. it was about as messy as a bike can get without damaging anything serious. he picked up a new set of farings, a subframe and a front wheel, whallah, spankin new blade :lol:
tuff as nails, i dont think 954s die, i just cant fathom what would be needed to break one of these :lol:
i guess they go hard too..... weighing 1/2 of fuck all and having ~150hp at the wheel with a slipon.....
racing hondas is like running in the special olympics
win or lose, you're still a honda rider...
99 ZX7R streetfighter
76 HJ Wagon kiddiekart
71 HQ coupe
http://www.99coconuts.com
jeebuz, 3 kids now.... anyone want one? free to a good home!
99coconuts
Postby SocialSecurity » Thu Aug 24, 2006 12:27 am
did he ever let you ride it dale? :wink:
they do about 135rwhp stock, little more with a slip on... about 145rwhp tops with a nice full system and tuning, they aint no gixxer :wink:
SocialSecurity
Postby Benno » Thu Aug 24, 2006 7:37 am
My e-penis is larger than yours.
Vespa!
Benno
Postby Neka79 » Thu Aug 24, 2006 11:59 am
SocialSecurity wrote:929's must be pretty weak if a 954 aint exactly scary :wink:
that right is it??
is that why a few of the aus superbike boys mounted 954 donks in their older 01 929 chassis for the 03/04 race season??
apparently ..so its been said..the 954 had a better donk/box..but the 929 had a better handling package....
i wouldnt kno..but u talk of how tame a 929 is..then u comment on the 9r as the "busa of the litre class"....hahahaha
PreviousNext
Users browsing this forum: No registered users and 16 guests
