Neutral Light - problem sorted out
Postby tape » Wed Mar 02, 2005 4:03 pm
Question for those that may know electrics?
What would cause the neutral light to come on every time the clutch lever is pulled in, even if it is not in neutral?
Mick :drinkers:
http://www.insptag.com.au
tape
re: Neutral Light
Postby Felix » Wed Mar 02, 2005 4:13 pm
A faulty neutral switch...
Ok that's not very helpful...I'll see if this here manual has anything useful...
- Team Furball -
Felix
State: Overseas
re: Neutral Light
Postby Felix » Wed Mar 02, 2005 4:21 pm
Looking in my GPZ500/ER5 manual a common theme is a Neutral switch (on the gearbox I guess) and a clutch switch (wonder where that could be??).
The neutral switch should be a wire coming out at around 7 -8 o'clock from the sprocket centre. They suggest disconnecting the wire to see what happens, and also removing the switch, the putting it back in without the sealing washer to check if that makes a difference. If removing the sealing washer works, then the plunger is worn and you need a new switch - do not ride it without the sealing washer! Put it all back together until you get the replacement part.
That's all I got, you're on your own from here 8)
- Team Furball -
Felix
State: Overseas
re: Neutral Light
Postby ty » Wed Mar 02, 2005 4:33 pm
I had the same problem on my ZZR - continued until the light was on all the time.
As mentioned it's likely your neutral switch near the front sprocket. Mine was clogged with lube - cleaned it up and all good.
ty
ty
Bike: Honda
Re: Neutral Light
Postby Flakey » Wed Mar 02, 2005 4:37 pm
tape wrote:Question for those that may know electrics?
That's almost the same thing anyway init? Clutch in = neutral... :D
Flakey
re: Neutral Light
Postby tape » Wed Mar 02, 2005 4:53 pm
Gone thru the service book and no mention, that I can find anyway of the workings of the neutral switch... it has wiring diagram but nuthin on how it works???? oh this is for the gpx 250
Mick :drinkers:
tape
re: Neutral Light
Postby ty » Wed Mar 02, 2005 5:20 pm
you probably won't find anything about the workings of it - but you should be able to locate it.
It's actually a sealed unit inside the gearbox, but will have a wire attaching to it near the sprocket. Just unplug the wire, clean it out, plug it back in, and see if it makes a difference.
ty
ty
Bike: Honda
re: Neutral Light
Postby Jonno » Wed Mar 02, 2005 6:15 pm
Nar, just get a bigger hammer. :roll:
re: Neutral Light
Postby Plaz » Wed Mar 02, 2005 8:31 pm
Just a thought (as this happened on my ZXR 750) the hole in the clutch lever (the one you put the bolt through) had gone oval, nuetral light came on because there was free play (not enough spring tesion to keep the lever taught). I replace the lever with an after market jobby for $19.95 and no more problems.
Bike shops wanted to replace the nuetral switch with prices from $95.00 too $280.00.
Plaz
re: Neutral Light
Postby mrmina » Thu Mar 03, 2005 12:46 pm
there is a short some where between the lever and the light.
could be the lever. but to get a better solution u need a multimeter to test and see where the problem is :!:
re: Neutral Light
Postby StarDrifter » Thu Mar 03, 2005 1:23 pm
tape, if your interested, i'd be happy to take a look for you, i'm in craigieburn most nights anyhow. no guarantees if mechanical problem though.
Learn well all the rules, so as to know how to break them in the proper manner.
http://www.funkycustoms.com.au
StarDrifter
re: Neutral Light
Postby mrmina » Thu Mar 03, 2005 3:40 pm
there u go tape. james is a sparky which help.
re: Neutral Light
Postby tape » Thu Mar 03, 2005 4:32 pm
Thaqnks guys I PM'd stardrifter, I just had it in at K & J Thomas's and they didn't even notice the light on...lol
cheers and thanks
Mick :drinkers:
tape
re: Neutral Light
Postby tape » Fri Mar 04, 2005 8:48 pm
James aka StarDrifter found the fault and temporarily fixed it so T has only neutral light when in neutral...lol I just gotta find a clutchblock switch from somewhere.
Thanks again James we owe you one.
Mick :drinkers:
tape
Users browsing this forum: No registered users and 3 guests
cron
