that brings me to my next Q. Where is a good suspension joint on the gold coast that can do this at a reasonable price ? (if u have had it done what was the damage?)
jpbikeboy wrote:If you just want to change the oil it's easy. you just have to take the top nut off and tip the old oil out and refil to the specified level.
mrmina wrote:jpbikeboy wrote:If you just want to change the oil it's easy. you just have to take the top nut off and tip the old oil out and refil to the specified level.
mate doing the forks is not that easy..... It requires a bit of being clueie otherwise u can fark them up
photomike666 wrote:jpbikeboy wrote:If you just want to change the oil it's easy. you just have to take the top nut off and tip the old oil out and refil to the specified level.
Should have a drain hole, so probably won't even need to remove the forks - just keep the front lifted. Check oil grades and volumes before you start. 1ml difference between the forks will adversly affect your handling.
