Hi all,
On a ride on the weekend the 08 zx6r was cutting out/down on power when:
under load, and
hot, and
into the higher rev range (started loss at around 8k, dead above 10k)
Does happily rev in neutral.
Thinking to first clean the fuel pump/pickup filter.
Next replace plugs (hasn't been done in years)
Clean injectors?
Throttle bodies?
PC3 getting hot and failing?
Any thoughts?
Tim.
Power cutting at higher rev range
- tim
- MadKaw
- Administrator
Re: Power cutting at higher rev range
Yep, all the above..
Sounds like a fuel blockage or pump issue.
Maybe try a different map on the PC or remove it see if that is an issue.
- KiwiMat
also...
cant hurt and cheap as, to run some decent injector cleaner through the bike, but i had exactly the same prob on a recent GSXR600 i fixed up, put a $120 fuel pump kit through it, went hard after that, i still reakon the injector cleaner helped.
Pinched or bend fuel line that bends more when hot?
just throwing a few out there.
KiwiMat
KiwiMat
ZX12R - 2005
GSXR750 - 2022
FZR250 - 1990
ZXR250A... project
GSXR750 - 2022
FZR250 - 1990
ZXR250A... project
- tim
Thanks guys! Haven't got back to it yet, but yeah fuel line is a possibility (I did have the tank up refitting some parts) and will try some injector cleaner.
I did a fuel pump kit 2 years ago - this one
https://www.ebay.com.au/itm/154365836327
not sure on the quality.
Will update
Will update
- James
I had the same issue on a ZX7 that was due to the battery. I replaced it and all good!
yep, or even check the terminals are tight.James wrote:I had the same issue on a ZX7 that was due to the battery. I replaced it and all good!
