ZRX 1200 R 2008
ZRX 1200 R 2008
I'm looking at a zrx1200 r to buy but and when i started it up it had a ticking sound for 10 to 15 seconds and wondered if anyone aware of any known issues with happening on a these bikes. I had a 2001 zrx 1200 s model but always started it every few days and don't remember it happening on my old bike.
Mr Plow
Mr Plow
s man
Re: ZRX 1200 R 2008
Could be the type of oil your using?
- billwest
- Bike: ZZR1200
- State: Western Australia
Re: ZRX 1200 R 2008
Could be a bit of valve/shim noise when cold. Once the oil gets up there it goes away.
Ride as if you own the bike!
ZZR1200 ('02), FJR1300 ('19).
- Glen
Re: ZRX 1200 R 2008
Mine does exactly the same thing. Goes away after 10 secs or so and hasn't been a prob
bonester
Re: ZRX 1200 R 2008
Could be loose alternator nut, or camchain. My better ZRX has some camchain noise- always has and it also had the loose alternator nut thingo. I imagine you are looking at the 08 for $7700 in Adelaide with 30 odd thousand kms on it. Got a friend here looking for ZRX and sent her details of that one. Too far away but looks a reasonable bike at a good price.
Yeah I like Kawasakis.
- Glen
Re: ZRX 1200 R 2008
If it's the same as mine the noise is from the top of the engine?
Once the oil gets up there it seems to go away.
s man
Re: ZRX 1200 R 2008
Use a different oil. When I had my ZRX I used castrol 4T Never had a gear change issue, or any strange noises ever.
http://www.castrol.com/en_au/australia/ ... -oils.html
- Strika
Re: ZRX 1200 R 2008
A good quality oil like Coles Black & gold or Aldi oil will solve all your problems.............
- Glen
Re: ZRX 1200 R 2008
I thought you were into baby oil y'oldcahn.Strika wrote:A good quality oil like Coles Black & gold or Aldi oil will solve all your problems.............
What's happening mate?
- Linc
Re: ZRX 1200 R 2008
Mine also has that light ticking sound. It's never caused any problem that I know of, my mechanic at Kawasaki was not in the least bit concerned about it either. You could try running some Seafoam through the fuel, which may help breakdown any varnish build up in the engine and generally lube and clean the carbs and other moving parts.
2005 ZRX 1200R
