slip on for my z1000 2014
bige
Post by bige »
Hi All,
Would like to know if i put on my vans and hines urban brawlers slip on muffler and take the standard mufflers off would i need exup valve or can i simply disconect the cable and just leave there?
Thanks
Re: slip on for my z1000 2014
If you disconnect them it will show an EFI fault. There's a block off kit you can buy. But I would just leave them. Unless replacing the headers, I see no real point. It should run fine with the Vance and Hines. It will of course run even better with a Power Commander.
s man
Post by s man »
You disconnet the cables from the servo & take it all away with the mufflers. [ the servo stays attached to the wiring, so the ECU isnt interrupted.
Then fit a pair of slip on's, on it & it'll be fine. It will run a little lean on over run & burbble a lot under 3000rpm, but it will sound great & you'll get around 6HP gain. I have a EJK on mine, which works well.>>> http://www.electronicjetkit.com/EJKkeyfeatures.asp
They make twins mufflers for the 2011/2014 Z1000 like these>>>
http://www.ebay.com.au/itm/Kawasaki-Z80 ... 27e261636f
greenmeanie
Post by greenmeanie »
You can remove the cables no worries just take care removing the top end of the cables from the pulley on top of the servo motor. If you move the pulley it can throw an EFI fault code then could you remove the servo motor & run a servo buddy to get rid of fault code.
I've had my Vance & Hines muffler for over 3 years & never had an EFI fault code appear. ;)
Glenn
2009 ZX10R
bige
Post by bige »
thanks all, removed the standard muffler, and gently removed the power cables, and on went my vance and hines.....sounds and looks awesome............could'nt drive too much as the weather was crap, but prob on the weekend if it clears up, cant wait to carbon the insides.......once again thank you very much....appreciate.
