ZX10R forks
greenman43
ZX10R forks
Post by greenman43 »
Can anyone confirm whether the 04-05 forks are the same dimensions as 06-07 please ?
Have found an intriguing set of triple clamps to fit 04-05, looking to see if I can use them on my later bike. The two measurements are obviously the diameters at the upper and lower clamps. Even if I can get those numbers for an 04-05, I'll check myself.
Thanks in advance,
Brian
Aussie Ninja
Re: ZX10R forks
Post by Aussie Ninja »
I'll pull out my verniers tomorrow morning some time and get you the diameter of my '04 forks just above each clamp.
1998 ZX6R R.I.P.
2004 ZX10R killed by Roo.
2011 ZX10R
Aussie Ninja
Re: ZX10R forks
The fork diameter at the top clamp is 50mm and 54 mm at the bottom clamp. I measured both above and below the clamps. This actually surprised me a little as I had never really thought about it before, but assumed that the fork tubes were the same diameter for their whole length.
1998 ZX6R R.I.P.
2011 ZX10R
ZX-10R_04
State: Tasmania
Re: ZX10R forks
Post by ZX-10R_04 »
The 04 05 ZX10R forks have a smaller axle on the front wheel than the 06 07 ZX10R
04 ZX10R & 08 ZX10R
greenman43
Re: ZX10R forks
Aussie Ninja wrote:The fork diameter at the top clamp is 50mm and 54 mm at the bottom clamp. I measured both above and below the clamps. This actually surprised me a little as I had never really thought about it before, but assumed that the fork tubes were the same diameter for their whole length.
Thanks mate, much appreciated. As the lower clamp is where the suspension and braking forces are concentrated, its whay needs to be beefy, so the top part if the fork tubes and clamp can be smaller.
Brian
greenman43
Re: ZX10R forks
ZX-10R_04 wrote:The 04 05 ZX10R forks have a smaller axle on the front wheel than the 06 07 ZX10R
Thanks muchly :)
Brian
JimZXR
Bike: ZXR750
Re: ZX10R forks
Post by JimZXR »
What will be happening to the removed set Brian?!?
1993 ZXR750 Track Bike
1994 ZXR750 Ongoing project
greenman43
Re: ZX10R forks
At the moment I've got a set of Attack adjustable offset clamps, but I'm musing over lashing out and getting some magnesium ex-WSB clamps. Quite likely won't happen, just wanted to do the research first.
Brian
