I've done some research and I think I could actually do nothing and it will be fine however that will leave me with an annoying warning light permanently up, anyway this is what I've found out......
1- the original exhaust has an exhaust ultimate power valve (EXUP) that opens and closes relative to whether you are idling through to opening it right up.
2- I bought it with an IXIL Xtreme exhaust which does not have this valve (as most after markets don't)
3- the valve is controlled via a servo motor on the LHS of the bike.
4- normally in the kit for the exhaust is a plate that you attach to the servo motor replacing the pulley on it (which has cables running to the valve on the exhaust). This plate is to fool CPU so that the FI light doesn't come up.
5- all of the above is fine but my warning light is on and upon further investigation the servo motor is cactus....seized cog and burnt out.
6- I have come across a little 'adapter' called a servo buddy (can get from eBay for about $80) which is supposed to eliminate the need for the servo motor all together leaving no warning light coming up, you just plug it in where the servo motor would normally plug in to.
Does anyone know of these 'servo buddy's' and if what I've researched and investigated is correct?
Cheers in advance
