zx14 new Map done on dyno
xlur8
Post by xlur8 »
Hey guys i just bought the zx14 decided to take the flies out so decided it needed a new tune here is when it had the Power commander put in and tuned about 6 months ago
And this is the tune i had done today 11/1/13 very different results Can anyone tell me if the new tune is ok i thought it was abit low but i havent much of a clue on the readings cheers
Re: zx14 new Map done on dyno
Different dyno's are calibrated very differently. Don't be shocked to loose or gain 15-20hp from shop to shop as some are more realistic than others
The power curve on the second looks good, very linear.
xlur8
Post by xlur8 »
thx for the reply cheers
Blurr wrote:....The power curve on the second looks good, very linear.....
they started with a great motor and just made it better :lol:
xlur8
Post by xlur8 »
Also guys if i take the baffles out of the yoshi mufflers will that effect the tune ??
Yep but whether it is positve or negative to power output cant be determined without a dyno.
Usually if the baffles are fairly restrictive you will loose back pressure.
This will generally give you alittle more up top but loose a little in the middle.
xlur8
Post by xlur8 »
Thanks Blurr will just leave it as is cheers man
