Kawa Z650 Help Assuming Carb Problems...
Nosmo
State: Overseas
Post by Nosmo »
Guud Day folks.
To start off, I am not extremely experienced with motor mechanics at all, but love to learn all the time. The thing is, I usually want to do it myself. I dont want to take it to a workshop and have things repaired by qualified okes and I dont want to ask a mate to look at and repair/adjust/modify. I want to DO IT MYSELF.
Now, just bought this old girl: (Dont know how to insert my pics on this forum yet)
The day i got her, she was going fine. Not 100% if I opened her up, but I was assuming that she needs some TLC, some fine carb adjustment, new spark plugs etc.
The next day, I took her out on the open roads with my friend. We rode the whole day, but at approx 5pm in the afternoon, she started to cut out, almost seemed to me as if she was running out of fuel. This could not have been possible, I thought, as I filled up the tank just before heading out the rather deolate, winding stretches of road along side the ocean.
So, I thought the petcock was blocked up. Eventually found a little pud with a guy that had some tools. Stripped off the petcock to clean the inside tank filter, but alas, the filter was clean.
Went on like this for quite a while. Eventually I got to a gas station and filled her up again. Immediately saw that the fuel just runs straight out again from overflow pipe on Carburetor No.2. I jumped on and rode her home, knowing now that I was actually running out of fuel the whole day en that float levels/stuck float bowel would probably be the problem.
Next day I took the carbs off. Adjusted and cleaned a bit with my limited knowledge, interweb and haynes manual. :o
Seemed to have fixed the problem of the petrol flowing out of the no.2 Carb. Took it for two short test drives and everything was fine again.
the next morning, I wanted to ride her all the way to work. It was raining, so I thought it would be a good test for the old girl, as I believe that water and older bikes tend to not go very well together. About 2km from my house, in the rain, she died. I pushed her all the way to a biker pub in the area and left her there untill I could return after work to check her out.
She stood in the drizzling rain that whole day. I took a bike mechanic with me and he could also not get her to start. Eventually I asked a random home owner if I could just get her his garage, just to be able to work a bit dryer. Eventually, after drying, cleaning, reconnecting, sealing, spraying, trying to start, she started and I could just just get her home, while running very rough.
The day after, I started to investigate a bit further, learning about the coils etc. I clenaed the areas where the points are, put new gasket and sealer. She started easily by this time, but was still missing quite badly. Then only, I replaced the spark plugs and she was perfect again. Again, rode her the whole day last Saturday and towards the end of my trip, once again she started to idle/rev rough and now she is standing again, parked. Starts immediatly, but misses like crazy. The spark plugs are black and smell like petrol. I cleaned them with sand paper, put them back and she seems to be missing even more than before I cleaned them.
I understand that this is a mounth full and I understand that there might bemany different probelms, but if you guys are kind enough to share some of your experience in this dept., I will take your advice and tick off things to be done to the old bird one by one, untill she can purrr across many miles of open roads. ;)
chimp
Re: Kawa Z650 Help Assuming Carb Problems...
Post by chimp »
Nosmo
when you took the cabs off you say you Adjusted and cleaned a bit Seemed to have fixed the problem of the petrol flowing out of the no.2 Carb...what did you actually do ? also did you check the floats are all level?
I took a bike mechanic with me and he could also not get her to start. " what did he say???"
The spark plugs are black and smell like petrol. I cleaned them with sand paper, put them back and she seems to be missing even more than before I cleaned them. "did you check the gap"
Have you checked your charge rate & if your rectifier is working & not breaking down under load??
Only a Motorcyclist knows why a dog rides with his head out the car window
Bikes:Zrx1200r Z650 Gpz750r Cbr1000f & Postie!
what year model is it Nosmo? Does it have normal slide carbs or CV carbs ?
Nosmo
State: Overseas
Post by Nosmo »
Hi guys
I checked the float levels. The number 2 carb definitely had more petrol in than the other 3. I adjusted the float bowel ever so slightly, to ensure that it closes the needle valve.
The bike mechanic oke could not seem to find exactly what was wrong and estimated that it might be some electrics getting wet. Advised that I spray everything with tool-in-a-can, which I then did. He went home after that. His wife is very strict. hahaha
Yes, the gap was and is still 100% correct! 0.8mm (states this in the manual)
I did not check charge rate or rectifier. You see, these are now things that I will try to read about, figure out how it works and how to check if all is well.
Gos, I have not been able to pin point exactly which year model it is, but the engine no is KZ650 BE 120397. Frame No is KZ650 0046. I tried looking all over the net for model specs on these numbers, but could not succeed. I am guessing 1977....
Now how do I know if it has normal slide carbs or CV Carbs? If you could briefly explain a major difference between the two, I would be able to tell you which one it is...?
CV carbs have big flat square tops - slide carbs don't. That is about as easy as I can describe it.... ;)
Nosmo
State: Overseas
Post by Nosmo »
Hi There
Eventually got the beast started last night. Adjusted timing and point gaps. Rewired the fuse connections. Replaced with baled in stead of the old glass type. I also did the relay mod which I only became aware of, because of this site, so biggup to all you guys! :-) Other than that, I checked spark plug gaps and cleaned and then noticed 3 of the four spark plugs are shot. replaced with the old incorrect ypes and the bike started. Is still missing, but actually managed to ride about 35km's this morning without any real problems, except for a loss of power. So, now I strongly believe that it must be the carbs overfuelling. Will check float levels and see if I can clean the needles. If anyone has any suggestions, tips and tricks, please do not hesitate to post here.
Shot allot!
bonester
Post by bonester »
Even with float height set correctly, carbs can overflow fuel if the o-ring between the seat and body of the carb is shot. Might be? :shock:
