White dry fluid?
Algeemo
Bike: ZZR250
White dry fluid?
Post by Algeemo »
Hi all, I'm new to site and bikes so bare with me haha :)
I've just bought my first bike a 1991 ZZR250, iv'e took it it for a few rides now but just the other day I notice my exhaust pipes had white spots on it, what wasn't there before. iv'e now taken a better look around my bike it seems to be over the frame too, and looks like its leaked from somewhere but I can tell where from. Its like a white oily powder, just wondering what this might be?
Wasn't too sure if this was the place to post this sorry if its in the wrong place. Cheers
6maniac
Re: White dry fluid?
Post by 6maniac »
Coolant leak ?
Oh, and welcome ...
I look forward to the comments on your thread title ............. :shock:
z900/zx9
Post by z900/zx9 »
Yep sounds like coolant
TONY-J
Post by TONY-J »
yep could be coolant, but on a side note it could aslo be battery acid from the overflow, my brothers gsxr had a white powder stain on the swing arm that was etched in an that was battery overflow.. especially if battery has just been replaced
84 RZ350
84 GPZ900r
91 ZZR1100
06 ZX14
6maniac
Post by 6maniac »
TONY-J wrote:yep could be coolant, but on a side note it could aslo be battery acid from the overflow, my brothers gsxr had a white powder stain on the swing arm that was etched in an that was battery overflow.. especially if battery has just been replaced
Wouldn't be "oily" though ??
It can either be oily, or a powder - but it can't be both :lol:
sounds to me like battery fluid overflow. Which is a bad sign, means the battery has been boiling - using fluid and creating a lot of gas - which also means the reg/rectifier is probably shot.
Algeemo - check the fluid level in your battery ASAP, and then get an auto-electrician to test the charging voltage - should be no more than 14V at around 4,000rpm on your bike.
If it stays oily, then it's probably radiator coolant. It's either leaking from the cooling system, or being pumped out from a gasket leak. Check the radiator, overflow bottle, water pump and hoses as well as thermostat and housing.
6maniac
Post by 6maniac »
Where on the exhaust & frame are the "white" spots ?
i.e. ... headers/mufflers ? front frame tubes/swing arm ?
Pics ??
Algeemo
Bike: ZZR250
Post by Algeemo »
Hey guys cheers for all the replies, yeah its a white powder just looked oily coz its mixed with grease from the chain. it has a irony smell like copper, I can't get the faring off due to a rounded nut ffs...but it looks like its came from the battery and coolant overflow area, the bloke I bought the bike from did say he just put a new battery in it, so my battery cooking? if so why does this happen is there a certain way you gotta put a new battery in a bike?
Oh I checked the coolant overflow theres coolant in it.
First things first...
Do you run a meth-lab in your garage?
If so it could be meth residue..
its happening because your regulator/rectifier unit is not working properly, the battery is over-charging and boiling itself dry - instead of fixing the problem and replacing the reg/rec unit, the previous owner just fitted a new battery.
This new battery will be fried quickly unless you replace the reg/rec unit.
Algeemo
Bike: ZZR250
Post by Algeemo »
Thanks for all the help guys, looks like i'll be forkin out a bit more to get it running properly cheers
White dry fluid?
hoffy wrote:First things first...
He's not from
Windsor Downs mate... :)
TONY-J
Post by TONY-J »
before you replace anything first figure out if there is a fualt, and check battery fluid levels becuase where i buy my battery's from they are dry and you get a bottle of acid with it.
someone could have overfilled the battery to start with.
good luck
84 RZ350
84 GPZ900r
91 ZZR1100
06 ZX14
Algeemo
Bike: ZZR250
Post by Algeemo »
TONY-J wrote:before you replace anything first figure out if there is a fualt, and check battery fluid levels becuase where i buy my battery's from they are dry and you get a bottle of acid with it.
good luck
Yeah will do, I got a mate who been around bikes for years, going to ask him to come around and take a look at it for me. just make sure im doing the right thing.
