Heavy clutch notchy gearbox and gear indicator out
mmamster
Post by mmamster »
All
Just finished 2 nd track day on my 08 zx10. A few issues, can anyone help.
First the clutch is very heavy compared to my old bike. Second the gearbox is notchy on downshift from 5 to 4. Third I hade the shift lever converted to race pattern and afterward the gear indicator isn't working.
The bike has done 14000kms. Is it just normal wear and tear to have a heavy clutch and notchy shifts?
Any fix suggestions on the gear indicator?
Mark
Mark
CBR1000RR 2009 roadie, ZX10R 2008 track
GSXR600 K7 road sold 12/09 (as a wreck)
GSXR600K7 racebike sold 10/11
ZZR 250 sold 2/2007
Jon13
Re: Heavy clutch notchy gearbox and gear indicator out
Post by Jon13 »
Gday,
Not sure about the clutch could be an adjustment issue, but if u have changed to race pattern make sure the geometry is right from the lever and linkage. the lever and rod should be as parallel as possible for a smoothe shift. Sometimes when you reverse the standard linkage you need to play around a little to find the "sweet" spot.
Jon13
Post by Jon13 »
Also the gear indicator issue could also be the same prob as its not quite in the correct position during shifting.
mmamster
Post by mmamster »
Thanks Jon will try that
Mark
ZZR 250 sold 2/2007
