zxr 750 rear wheel 1989
- steve086
- Bike: Honda
does anyone know if a later model zxr750 or zx9 rear wheel would fit on my beast?
- Jonno
- Mobile Chicane
Re: zxr 750 rear wheel 1989
What beast, on a Honda?steve086 wrote:does anyone know if a later model zxr750 or zx9 rear wheel would fit on my beast?
I can tell you this much, the wheels from a ZXR750 H1 are different to the wheels on a ZX9R B2
- steve086
- Bike: Honda
sorry a zxr750 1989, from what i can see the rear wheel's on the zxr750 91-95 and zx9 94-95 look very similar.
- Jonno
- Mobile Chicane
I tried reverse search the H1 part number # 41073-1415 and manually going through most years and models of most Ninjas Ronayres microfiche and no luck at all mate.steve086 wrote:sorry a zxr750 1989, from what i can see the rear wheel's on the zxr750 91-95 and zx9 94-95 look very similar.
but I will pm you as I have 2 rims myself for the H1
Unfortunately this model being the first is like a model on its own, nothing after it is really the same.
- laidback
Is there a site that specialises in the 750s...there is for the 9s and I found a listing there that shows what wheels are interchangeable.
One thing with the part number search is that different colours may have different part numbers.
i have a cross reference program from http://www.zedder.com/laidback1952 wrote:Is there a site that specialises in the 750s...there is for the 9s and I found a listing there that shows what wheels are interchangeable.
from a few years back when i bought a metric shitload of kwaka parts
the part number is correct
41073-1415
they then use different letter designations at the end to spec the colour
Cj and DH for lime green and pearl chateau grey
the part number above is only for zxr750 89 models
- Bike: ZXR750
ZXR J/ L model would fit with mods.The bearings would have to be changed and also you would need the Kush drive and sprocket carier.Also it would have to be respaced.steve086 wrote:does anyone know if a later model zxr750 or zx9 rear wheel would fit on my beast?
On the H1 the sprocket carier and kush drive is very large.The best thing to do if you can is put a H2 rear wheel in with the smaller kush drive that is used on H2/J/L and zx7 models.You would still have to adjust the spacers to put the H2 rim in.If you are going to put any wheel off the later zxr models in i would put the zx7 6 inch rim in.It would be the same amount off work.I have a spare zxrL model rear wheel from my bike as i have fitted the zx7 one into my L model.You are welcome to see if it would fit.Located in sydney south west.
Dus 0408 728 540
