zrx1200 cams
zrx1200 cams
can anyone give me the best option for replacing the zrx12 cams that are prone to pitting?
i have read zzr1200 cams bolt straight pin,can any one confirm this for me?
this is the only fault i,ve found on an otherwise great bike that has only 18000 ks on the clock.
Re: zrx1200 cams
If they are not pitted why change? But anyway ZZR1100 cams are sposed to give them a couple of extra hp up high.
Re: zrx1200 cams
they have started pitting that,s why i,m asking if the zzr1200 cams fit i,m not so sure if the 1100 ones do as i know that zrx1100 cams dont fit the zrx 1200
Re: zrx1200 cams
Kwick on ZRXOA has a few different options from memory, reground stock ones or Yoshimura from memory.
ZZR12 will bolt in a previously advised, they will rob some of that fantastic low down grunt that is so great about the ZRX.
Pity that ZZ12 cams are nowhere near as common as the ZZR11 ones.
Re: zrx1200 cams
thanks phil
i don,t really want to lose any of that low down grunt so i looks like a standard grind would be the best thing then have you had the same problem with yours?
Neale.
Neale.
Re: zrx1200 cams
Mine is an 05 model & if my cams start pitting, Kawasaki will be paying for it. It is a known manufactring fault & under the turms & conditions of sale , any manufactuing fault has to be fixed by Kawasaki. Even if the bike is out of the warrenty period. The thats the way I see it anyhoo..
Some good reading here>> http://www.ksrc-au.com/phpBB3/viewtopic ... ng#p462908
Re: zrx1200 cams
No issues on mine, 70K on it so far.zedman900 wrote:thanks phil
Neale.
- Strika
Re: zrx1200 cams
76k on mine. Cams looking normal at last valve adjustment which was only 1 or 2k ago. Wouldn't want to lose any of the bottom, or even the middle for a few more HP up top. I rarely rev mine over 6k anyway. I reckon if I have to rev it harder than that, I'm trying too hard.
Re: zrx1200 cams
Was there a model prone to this pitting issue. Like can we put a date on it, eg:: 03 models pit but the 06s dont, or what ever. Or is it from the 01 right the way through to 08?? That could help pin down the year this pitting issue started & ended?????
Re: zrx1200 cams
I think you'll find its been since the GPZ900, not a new problem AFAIK. Pretty sure that most models that have derivatives of this engine are prone to it.s man wrote:Was there a model prone to this pitting issue. Like can we put a date on it, eg:: 03 models pit but the 06s dont, or what ever. Or is it from the 01 right the way through to 08?? That could help pin down the year this pitting issue started & ended?????
- Strika
Re: zrx1200 cams
Yep Phil is right. it's been an issue since the GPz900. They have only been aware of the issue though since 1986, so give them some time to sort it ok!
- TopCat
Re: zrx1200 cams
Mine pitted at 12k ('06), got them reground under warranty (even though outside 1 yr). Now got 32k and all ok.
Tony
Tony
TopCat
73% of internet statistics are made up on the spot
