Wet or Dry?
ZZR 250, 600, 1100 & 1200
ducati_paul
Wet or Dry?
Post by ducati_paul »
Just wondering what's behind the cover indicated? I'm hoping it's dry i.e No Oil, then I don't need an engine cover, I've got away with not having one so far but if I know for sure I don't need one I'll be happier :?
IsleofNinja
Re: Wet or Dry?
Post by IsleofNinja »
Normally the w-pump on that side Paul ..... any Xspurts on this bike??? 8) :?
06 ZX10r , 95 ZX9r
07 FXST
Head_Mechanic
Bike: ZZR1100
State: Tasmania
Re: Wet or Dry?
Post by Head_Mechanic »
It is dry under this cover . It covers the Ignition timing sensor.
ducati_paul
Re: Wet or Dry?
Head_Mechanic wrote:It is dry under this cover . It covers the Ignition timing sensor.
That'll do me! I read it on the Internet it must be true! :kuda:
Thanks
Re: Wet or Dry?
Not sure about your model, but this is usually the iginition rotor cover - bottom of cam chain.
This holds oil on my zx10r and on my zxr750r and a cover was required...
ducati_paul
Re: Wet or Dry?
Hmmm. well it's due for an Oil change, maybe I'll just whip that cover off once I've drained the Oil and solve this once and for all! I was worried it was a stupid question when I posted it but it certainly doesn't seem to be common knowledge. :)
Re: Wet or Dry?
one way to find out, start the bike, have it running and loosen the bolts in the cap. will seen tell you in anything is behind it. :lol:
Re: Wet or Dry?
Wattie wrote: will seen tell you in anything is behind it. :lol:
I want some weed, same as Wattie is smoking :lol:
Re: Wet or Dry?
i dont think you want what im on, its quite obviously not good enough! :lol:
Re: Wet or Dry?
Paul I think the biggest problem is when the scrutes pull you up & ask where the cover is, you then have to prove there is no fluids behind ...... :?
Take a photo with the cover removed & keep it for just such an occasion ;) .... thats if it is dry of course.
Daisy
Bike: GTR
Re: Wet or Dry?
Post by Daisy »
Thanks
He had the cover off mine when he was chasing electric gremlins.
Madkaw, I think the cam chain is in the middle on the 600.
