N2
- timmyrocks
Re: N2
yer, its lighter and doesnt fluctuate in pressure as much
it even makes the bike handle better and gives you better tyre wear i have found
i even use it in my ute
Team Crash "09"
WR125 2004 Husqvarna
Team Crash "09"
- Glen
Re: N2
I run it in my XF falcon ute and it get's 300 kw on the bum dino.
- Blurr
Re: N2
n2 is so 90's.
Yakfat and tank foam is where it's at now. You need this to unleash the true power of the mini barge. Of course this must be done after removing all wiring looms.
- IsleofNinja
- State: Western Australia
Re: N2
now add a bit of Oxygen (O) to the equation it would be really funny!?
Facts about nitrogen for noobs:
>Less pressure fluctuation hot vs cold
>0% moisture content (see above)
>molecules 4 X larger than air = less 'seapage' through the beads / liner -
If you have access to nitrogen by all means -- do the forks/shock while your at it ie GPX/ZX-9 etc
- Nitrogen filled tyres will NOT improve riding ability though
06 ZX10r , 95 ZX9r
07 FXST
07 FXST
