The engine build #1
there is a saying '"Good ,Fast ,Cheap choose two " Im a person of modest means and I want fast so from the start the whole process will be strickly "budget " and what better way of saving a buck or 3 is to do everything yourself ,so with that settled off i set , sadly most of the engine build pics were lost forever when I had a hard drive crash ,but some still survive and they are posted below ,the upgrade consisted off the following
motor & transmission
custom sprockets 17,18 &19 teeth fronts 40 to 35 rears
gears undercut
clutch heavy duty springs and barnett mod kit
hi volume oil pump
oil pan modification
harmonic balancer removed
crank magna fluxed lightened and polished , new bearings
carillo H beam rods and bolts
custom JE flat top forged pistons 10:1 cr and rings
block bored 2thou oversize and o ringed
APE top and bottom stud kits
1mm Ferrea oversize S/S ex&in valves
heavy duty valve springs
Ti retainers
extensive head work porting
stock cams but adjustable sprockets
bronze valve guides
schnitz pro 2 ignition and nitrous controls
wet nitrous system 3 stages
dyna coils and leads
mikuni RS 38mm carbs
mikuni methanol kit ( fuel methanol )
custom exhaust system with EGT sensors
CHT sensors
full avionic instrumentation
and other stuff I cannot remember
these are pics of the head with the nitrous nozzles added
