LOST MY KEEEEEEEEEYYYSS! ALL OF THEM
ZZR 250, 600, 1100 & 1200
PaulF
Bike: Ninja 250
Post by PaulF »
Hey guys,
i lost all my keys and the keycode :oops: !!!
Did some research and it looks like it's a costly mistake. I have to pay about 250 $ for a set of 2 keys!
I managed to open the fuel cap and it had a code on it but Kawasaki dealer in Lane cove said that they need the key code from the ignition barrel which is a hassel to remove. Also looks like the VIN is worthless for this matter since you can't get the keycode from the VIN!!!
Any ideas guys before i call a locksmith :cry: ??
Rossi
Re: LOST MY KEEEEEEEEEYYYSS! ALL OF THEM
Post by Rossi »
Breakers yard ?
PaulF
Bike: Ninja 250
Post by PaulF »
Hey Rossi,
thanks for your prompt reply :)
I'm guessing your'e suggesting that i change the whole ignintion??
Johnnie5
Post by Johnnie5 »
remove the tripple clamp with the lock and take it to the locksmith
independant in parra or the locksmith in booth st annandale or another one in the same complex as MAW
about $60for 2 new keys
PaulF
Bike: Ninja 250
Post by PaulF »
Hey Johnnie5,
isnt removing the triple clamp a b@@tch ?? :cry:
I never tried it but i heard that i have to drill through the screws or something?
Some more info would be greatly appreciated please.
Not remove just the barrell Paul, but remove the entire top triple clamp!! It's the one that houses both the ignition barrell and the fork tubes! Remove tank, undo the headstem and triple clamp pinch bolts, Remove handlebars (depending on if they are clip ons or not) unplug the electrics and voila, slide top triple clamp off. It's a 20 minute job for someone who knows and a good hour if you don't. :)
Rossi
Post by Rossi »
All the barrels are "keyed alike" so a good locksmith will replicate your keys from any one of the barrels........either seat lock or petrol filler cap should do ;)
Johnnie5
Post by Johnnie5 »
Rossi wrote:All the barrels are "keyed alike" so a good locksmith will replicate your keys from any one of the barrels........either seat lock or petrol filler cap should do ;)
is that the case on the kwaka ?
eg old hondas the petrol cap uses a few pins and the seat lock uses the other few pins of the key so a locksmith can make the ignition key from the other 2 combined
PaulF
Bike: Ninja 250
Post by PaulF »
Hey guys :)
I managed to remove the side fairings and read the code on the seat lock barrel
it's in the following format:
232-1d42
Is this the keycode or is it a part number ?
Rossi
Post by Rossi »
Buggered if I know .............all I know is the same key fits 'em all ;)
Daisy
Bike: GTR
Post by Daisy »
I took my ignition key which fitted all three locks, along with the number I got from the seat lock, and the locksmith told me that if he cut a key from that number it wouldn't match the ignition key I'd given him.
PaulF
Bike: Ninja 250
Post by PaulF »
Hey Daisy,
My key was a combination key too so i'm guessing the key from the seat lock wouldn't work :cry:
Any ideas where on the ignition barrel the key code is written, like if only remove the black plastic piece around the barrel, would i be able to see
the key code.
Thanks for you help!
Daisy
Bike: GTR
Post by Daisy »
Sorry, I can't help with the ignition. I've only removed the other two - and there is no number on the fuel cap barrel BTW.
PaulF
Bike: Ninja 250
Post by PaulF »
Done some more research and it looks like the Keycode number has the following format:
Z#### and also many forums keep on saying that you can get the keycode from the helmet lock but the bike didn't come with one :cry:
Hopefully tomorrow a locksmith will be able to make a key without the code , i dont want to remove the ignition, this will be my last resort!!
Daisy
Bike: GTR
Post by Daisy »
The ignition isn't all that hard to remove. Just fiddly and time consuming. They should be fixed with two shear head bolts. These can usually be removed with a centre punch, a hammer and lots of patience. The biggest problem is the stuff you have to remove to get to the base of the ignition.
Personally, I pull stuff like this apart because I'm too tight to pay someone. ;)
