Blonde Question - Tokico Calipers
cowasaki
Bike: GPz500
Post by cowasaki »
Yup.. dumb blonde question.
Been through my manual thingie.. but I still need to ask.
Will Tokico 6 pot calipers from a 02 zx6 fit my 95 zx6 that currently has only 4 pot Tokico's on it ??
Thanks
Carly
greenman43
Re: Blonde Question - Tokico Calipers
Post by greenman43 »
No worries, my wife’s blonde so I speak the lingo fluently :)
Not a dumb question Carly, but there's quite a few technical things you need to look at ; unless someone else has already done this and can provide practical experience, here's what needs to be considered :
• Distance between centres of the mounting points on the calipers – will it bolt straight up to your forks, or would it need an adaptor bracket
• O/D of the disc - is the disc a larger diameter on the later model
• Width of swept area of the disc – measure from the outside of the disc to the inside of the swept area (area that is touched by the pads) ; chances are it’s narrower on the 6p disc, I don’t think this would affect you as long as the pad width is no more than the swept width
• Disc offset : place a 6p caliper over the disc, and see where the mounting lugs are relative to the holes in the caliper – it’ll be obvious straight away whether a) the holes line up, b) you need to have spacers made and get longer high-quality bolts, or c) you’d need adaptors made
• The 6p caliper will have a different bore area to the old 4p (that is, if you take the radius of each individual piston and calculate the area using Pi R squared, the 6p almost certainly will be more than the 4p). This will change your hydraulic ratio, and if the new calipers have more area, your brake lever will have a lighter pull with more travel, it will have more power, but it will also have less feel (not necessarily good under heavy braking). I once swapped a ZXR 5/8” master cylinder for an R1 14mm unit, and the difference was astounding. The easy solution here would be to get a matching master cylinder for the calipers.
I can’t think of any thing else, maybe someone else will point out something I’ve missed.
All the best,
Brian
You could easily have some adapter brackets made to suit. However, if you are after a bolt off bolt on solution, go hunt down a set of GSXR1000 K2 (2002) six potters! they literally bolt straight on! ;) Oh, and a M/C which pushes a touch more voulme than the stocker also helps! One off a K2 etc.,!
cowasaki
Bike: GPz500
Post by cowasaki »
wow... great replies.
Thanks heaps........ will do the checking and hopefully get a better idea of what the hell goes on with my bike.
Carly
greenman43
No worries, have fun :)
Brian
