Rebound Problem????
- Burky
Rebound Problem????
After playing around with the rear (suspension) the rebound still seems slow to return. The dial on the bottom of the shock will keep turning and does not seem to have any impact on settings. Once you sit on the bike the rear drops a little, bounce on it and it will drop a little further but does not return quick at all. Is this common on sports bikes? a mate who rides dirt bikes said that it should return quicker than that. Any idea's would be great.
The bike was always hard in the ass but just wanted to get it a bit softer.
- MadKaw
- Administrator
The dial on the bottom has 4 positions on it.
If you look closely and its clean you will see the numbers 1 to 4 on the dial. 1 being softest 4 being hardest although at this age the shock probly needs a rebuild so put it on 3 or 4 but it may not make much difference...
Try adjusting the preload..
it was $170 from memory.burkys_ninja wrote:Just out of curiosity what is a rebuild worth aprox
that was oiled, gased, bushed, shimmed.
mine has no rebound. when u compressed the rear suspension using the love handles, it took ages to come back up. I did mine at about 30,000kms.
- Strika
That means there is too much rebound Mina!mrmina wrote:it was $170 from memory.burkys_ninja wrote:Just out of curiosity what is a rebuild worth aprox
- Nanna10r
- Team Ninja
As "Narfie" Said Mina's a BIG UNIT $170 wouldn't get him a Sponge bath let alone a full work up.burkys_ninja wrote:Was that the shock or umrmina Posted: Sun Oct 01, 2006 3:07 pm Post subject:
