Fuel filter in the 03-04 636??
- varden
I can't seem to find anything that remotely resembles a fuel filter between the fuel pump and the fuel rail on my ZX6R track bike.
This only bothers me cos I've had some issue with misfiring and flatspotting lately....a problem i possibly would not have if there was some kind of fuel filtering.
I'd like the peace of mind of a fuel filter.
Question is if i add in an in-line filter between the fuel pump and the injector rail will the bike stop working properly due to a possible change in fuel pressure????
- Nanna10r
- Team Ninja
Someone more 'kanically minded then i can answer the tech side of the querie Glenn but I can't imagine it doing any harm. If anything it would even out fuel pressure. Clean fuel has to be a good thing. Right ?.
- Duane
Vardy,
I assume (to make an ass out of you and me) that you run your bike on PULP. being a track bike, you dont go through the fuel so often as road riders do, and getting down to the servo (you can't just ride it)
This could be because PULP has a very short shelf life. Try flushing the fuel out completely and putting new stuff into it, may fix it (worth a try). Can't imagine any problems with putting a fuel filter in - maybe worth flushing the fuel, give it a go, then if not, splice the fuel line and put a filter in.
Also chuck a bottle of injector cleaner in (well not the whole bottle, but part there of, may be crap in the injectors)
www.bromancer.com.au
- varden
Hmmmmm that may well be part of my problem, the fuel that was in the tank at start of day was a mix of vortex and what was left from a trackday 3 weeks prior.Duane wrote: This could be because PULP has a very short shelf life. Try flushing the fuel out completely and putting new stuff into it, may fix it (worth a try). Can't imagine any problems with putting a fuel filter in - maybe worth flushing the fuel, give it a go, then if not, splice the fuel line and put a filter in.
For session 2 i added some fresh BP 95 and some fuel injector cleaner, the bike got slowly better during session 2 and session 3 but after that i was back to using vortex and the problem came back with avengance.
I brought a fuel filter yesterday ($2) and I'll splice it in during testing to see if it upsets anything.
But from now on the bike will only be run on fresh BP 95, my car thats been runing on the same vortex has been playing up lately, hard starting and misfiring at over 5500rpm
SocialSecurity
- State: Western Australia
blackninja
i reckon you should run BP ultimate in it .. thats what my bike was mapped on and it goes pretty damn good
i think you should pull down the fueling system and give it a good clean out and inspection dude, then put in the fresh fuel and go from there, its better to do the hard yards than search for a 'band aid' kind of solution imo!
SocialSecurity
