500km Oil Change?
Felix
State: Overseas
Post by Felix »
frogzx12r wrote:...it might be YEARS but the motor MUST suffer. THINK about it.
By that time I will have traded it in and it will be well and truly someone else's problem :lol:
I'm not saying don't do it...I just don't see the value in it. Who picked 500k's as the scientifically determined change point? Why not 250? 100? Each and every run? Maybe we should go back to the good old days of total loss systems :lol:
All motors wear, it is a fact of life. But I still think the engineers determine the best way to maximise the life of the engine, so I'll keep sticking to their recommendations.
- Team Furball -
I-K
Post by I-K »
hoffy wrote:look at it this way, the engineers of motorcycles dont get paid eleventy billion dollars to fuck shit up.
Neither do the marketing people, and when they argue, no doubt against the advice of the engineers, that the first service be no sooner than 1,000km because the customer would consider it onerous to return their bike to the shop at the 100km and the 500km mark, they win.
I-K
Post by I-K »
ty wrote:That's what it comes down to - who's right and wrong is a hesaid-shesaid argument that'll go nowhere.
No, it isn't. Those who argue that changing the oil before the 1000km service because the manufacturer says not to bother are wrong, for reasons which have been amply stressed by a number of people.
This isn't politics, it's mechanics. There's a right answer and a wrong answer, and "Manufacturer knows best, so I'll keep doing as they say" is the latter.
ttc
Team Black
Post by ttc »
actually on same topic but little off track..
bike's now on 13,600km
hasn't had its 12,000 yet
suppose to go riding tomorrow, or should i hold off until i get it serviced??
rotaboy
Post by rotaboy »
u could always drop the oi/filterl tonite if u got some fresh stuff on hand
ttc
Team Black
Post by ttc »
not tonight, busy :)
just want to make sure it's ok to keep using it till i get it serviced..
rotaboy
Post by rotaboy »
i would say go 4 it after all whats 200-400 km if your already over
if the oil is in bad shape i would say no however (track day in there or something)
hammer
Team Black
Post by hammer »
tanyathecheeky wrote:actually on same topic but little off track..
It will be fine that motor is fairly understressed
Ride it like you hate it
Neilp
Bike: ZZR1200
Post by Neilp »
The servicing dept will put synthetic oil in your bike at the first oil change, if the rings arent bedded in by the 1000 k service they arent going to.
Neil
Felix
State: Overseas
Post by Felix »
I have an open mind, so I'd like to see some proper figures on this. I'd accept any kind of empirical data that shows engine life deteriorating over time depending on when original oil is changed...and then I'll be in a position to determine whether I care :lol:
If it is the difference between my engine needing a rebuild in 100,000 km instead of 120,000 km then I don't :lol:
- Team Furball -
Neilp wrote:The servicing dept will put synthetic oil in your bike at the first oil change, if the rings arent bedded in by the 1000 k service they arent going to.
Neil
well, no they won't. Any dealer that did that to a new motor would be a total prick.
Its not just a matter of the rings bedding in, its the entire motor/gearbox that needs to be considered. The rings are just a small (though important) part of the bigger picture. The gearbox certainly won't have 'bedded-in' by the first service at 1000km.........
I got some advice about my 12 (well after it was needed :roll: ), by a bloke who has owned quite a few new bikes over the years......
His advice was - Ride the bike home from the dealer, and *Immediately* dump the original oil and filter, replace with new filter and same oil that dealer will use at first service (1000km).
Ride 3-400km, then dump this oil, and replace as above.
Then take bike into dealer for its *first* service......all the above advice assumes that you intend to keep your new bike for some considerable time, not just until upgrade time, in which case do everything as cheaply as possible........
ttc
Team Black
Post by ttc »
the kwakka workshop put motul 5100 in the new bikes after the first 1000km
thanks Stu :)
tanyathecheeky wrote:the kwakka workshop put motul 5100 in the new bikes after the first 1000km
thanks Stu :)
thats fully synthetic?
My dealer would not run full synthetic oil until the 12k service. It was semi-synth up to that point from the 6k service, and full mineral oil for the first 6k. Thats what they did for my 12 in any case.
ttc
Team Black
Post by ttc »
Semi, it's what they use in 90% of the bikes
