Riding in the rain
clay
Bike: Ninja 250
Re: Riding in the rain
Post by clay »
Can I just use car oil for the meantime?
Till I haul ass back to MCAS tomorrow and get some chain lube and oil?
Mate i saw some (silkoline) at Supacheap for $14 per can......... grab yourself a bargain...... please dont use the car oil as it will fling everywear including your rear tyre :lol:
smithy5
Post by smithy5 »
clay wrote:Can I just use car oil for the meantime?
Don't panic it won't rust overnight...... You can get chain lube at Supercheap auto cheaper than MCAS......... I use Fuchs Silkolene Chain Gel.........
Wardy
Post by Wardy »
Chain maintenance is something you need to do regularly. And also remove the front sprocket cover every now and then and clean it up. You will get a lot of gunk in there. Best to get an aerosol type lube like silkolene or motul that won't fling off as much. Supercheap sounds like the go, I'm due for a can soon also.
06' zx6r limited edition
Don't use that, it won't penetrate and may end up flicking all over your tyre making the slippery wet weather
the least of your troubles ;)
clay
Bike: Ninja 250
Post by clay »
Sweet, thanks guys. I'll go to supercheap tomorrow then.
My bike has no centre stand, what a pain.
Any idea how much a set of stands are for a Ninja 250R and where to get them?
Should make maintenance and oil changes etc a whole lot easier.
PM kaneg, he sells them and cheap too :kuda:
Nelso
Post by Nelso »
clay wrote:Sweet, thanks guys. I'll go to supercheap tomorrow then.
Get a rear stand and swingarm spools from Kaneg. He's one of the sponsors here. :kuda:
As for riding in the rain, you just need to slow down to double the recommended speeds on corners. :D
EDIT: too quick for me Seiko
clay
Bike: Ninja 250
Post by clay »
Sweet, thanks guys.
PM Sent.
Even in perfect conditions I'm barely taking corners at the recommended speed.
clay wrote:Even in perfect conditions I'm barely taking corners at the recommended speed.
:lol: one step at a time ;)
Jaykay
Post by Jaykay »
Don't stress to much about no centre stand. They are easy enough to lube up without one... You just have to lube what you can see. Then push the bike forward a bit to expose the next dry section... Oh and try and do your lubing just after a ride (when its warm)
Do what you do, and do it well...
Good idea of wet corners is to corner slightly slower than usually but 1 gear higher, this will make the bike less throttle responsive and less likely to spin the rear.
Gav
Post by Gav »
Good on you mate for posting and asking questions.Thats the way you learn, and the folks on this forum are more than happy to offer good advice... :)
shinnynoggon
Post by shinnynoggon »
the only way you become a better rider in dry or wet is ask,listen and practice,,,,,,you'll well get there "grasshopper" ;) :D
zx12r 05 roady "black betty"
zx12r 00 roady "midori"
zx9r 99 tracky "weed"
