Do you know how to administer first aid should a fellow mate injures himself coming off a bike?
If not and you would like to know read on.
The aim is not to shock people into taking action, however to make you aware there is a lot you can do to prevent death or improve the condition of the person, should you choose to engage in rending assistance following a trauma.
You don’t need to have a wealth of medical equipment nor be a doctor, nurse, ambo etc. to render basic life support. Just know that the contribution that you implement whilst you wait for an ambulance does make a difference.
Death as a result of trauma occurs during three time periods, we refer to them as peaks, and I will discuss the first two as they are most applicable to a trauma.
The first peak of death occurs at the time of injury. It may be instantaneous or within the first few minutes and is due to overwhelming primary injuries to major organs like the brain, heart or major vessels. In this situation there is not much can be done, although quick intervention may salvage the situation.
The second peak lasts from the end of this first period to several hours. In this peak we have the “golden hour”; research shows if basic life support is instigated within the first hour of injury then the outcome for the patient becomes a lot more favourable.
Basic life support prevents secondary injury occuring as a result of the primary injuries. The secondary injuries what we are trying to prevent is hypoxia (lack of oxygen in the body) and haemorrhage (loss of blood). We can temporarily correct hypoxia with CPR and haemorrhage with fluids, the use pressure to a wound & elevation of a limb as an example.
With this is mind we can now move onto assesing and instigating care in trauma situation.
There are multiple algorithms used on how to approach care, there is no set hard and fast rule in which algorithm you use, as long ABC is incorporated into the alogirthm your half way there.
Danger & Cervical Protection
In any trauma situation you want to do best not to endanger yourself or the injured person further, so if there is something obvious that will cause it then use your common sense to lessen or remove the danger.
