Wireless Router Problems
Postby tape » Wed Aug 05, 2009 9:44 pm
Is it possible to change the frequency of the Belkin G+ Mimo F5D9230-4 Wireless Router which is 2.4GHz to something else? I have looked all over for the Mexican Gardener but cannot find heem....
Looked on-line but cannot find out, (but I'm searchy challenged also) :oops: . If you could give a damn, I'd be interested in hearing if anyone knew a way of altering the farker... :roll:
Mick :drinkers:
http://www.insptag.com.au
tape
Re: Wireless Router Problems
Postby MrWasabi » Wed Aug 05, 2009 9:49 pm
do you mean change the channel or the actual frequency?
Mistakes:
MrWasabi
Postby tape » Wed Aug 05, 2009 9:57 pm
MrWasabi wrote:do you mean change the channel or the actual frequency?
The frquency sends at 2.4GHz and it's the same as something else in the house that also sends at 2.4GHz so I wanna try changing the one that may be able to, and I do not know if it is possible yet. If that makes sense???? :oops: :shock: :roll:
Mick :drinkers:
tape
Postby MrWasabi » Wed Aug 05, 2009 10:04 pm
if you log in to the router, go to the wireless section and there is a section where you can change the channel. Typically 11 and 6 are used. But try and change it to something else.
Mistakes:
MrWasabi
Postby Smitty » Wed Aug 05, 2009 10:10 pm
MrWasabi wrote:if you log in to the router, go to the wireless section and there is a section where you can change the channel. Typically 11 and 6 are used. But try and change it to something else.
Mick
you should be able to access the Belkin via a browser page (using firefox or IE)
it uses an address of 192.168.2.1 (just type that into the browser address field) ......and it will then ask for a password
(which will be password or administrator or similar-check yr manual) and on the left hand side of the page under -
Wireless, it sez -
Wireless and SSID
jump in there and change the channel
make sure you hit the 'apply changes' button when done
hth
Postby tape » Wed Aug 05, 2009 10:11 pm
See, now that where we start having troubles...lol
How the fark do I log into the router? It is, (the wireles router that is), is connected to the ADSL modem then connects to another computer. Then by some voodoo magic occurs and the lap tops work :shock:
Seriously how do I log into the router? :oops: :?
Mick :drinkers:
tape
Postby Disco » Wed Aug 05, 2009 10:14 pm
I use this to log onto my laptop at work maybe it can hep you help him :D Team viewer
Team Monster
Postby Smitty » Wed Aug 05, 2009 10:14 pm
tape wrote:See, now that where we start having troubles...lol
you cant do this on one of the laptops (its getting the wireless signal remember and you are wanting to change that!)
you have to do it on the PC that the Belkin is connected to..to which yr ADSL modem is connected to
which is connected to the phone...
which is connected to the knee cap and the knee caps connected to :lol:
afterwards you will have to re-set the laptops access
(delete the wireless network and ask it find the wireless signal again)
PITA I know...but its the way i got it to work
Postby tape » Wed Aug 05, 2009 10:14 pm
Mick
Wireless, it sez -
Wireless and SSID
hth
Ian.... I'm farkin sober :shock: I barely understood a word you typed... :oops: What do I or where do I put that IP addy you said? and then what???? :roll: :? :?
Mick :drinkers:
tape
Postby Smitty » Wed Aug 05, 2009 10:18 pm
Mick..on the PC open up a new web page ..which will open up with the stored 'home page'
does not matter whether IE or Firefox or Mozilla..any browser
wipe the address at the top thats there and then type in 192.168.02.1 (no www or http needed) and hit enter on the keyboard
Postby Smitty » Wed Aug 05, 2009 10:21 pm
also..if u dont have it...cant find it
the manual for the Belkin is here -
http://cache-www.belkin.com/support/dl/ ... manual.pdf
beware the Belkin site is slow :roll:
hth
Postby MrWasabi » Wed Aug 05, 2009 10:22 pm
grab the manual, because not all routers have the same default ip.
Open internet explorer and put it in where you normally put in a web address. The user name and password should be in the manual as well.
Mistakes:
MrWasabi
Postby MrWasabi » Wed Aug 05, 2009 10:24 pm
beat me to it. I cant provide tech support from my phone!
Mistakes:
MrWasabi
Postby tape » Wed Aug 05, 2009 10:25 pm
will give it a try tomorrow Ian, the other puter is now currently occupied... bloody kids :roll:
cheers and thanks
Mick :drinkers:
tape
Postby Smitty » Wed Aug 05, 2009 10:29 pm
the Belkin help number here is - 1800 235 546
just in case.... :lol:
Next
Users browsing this forum: No registered users and 14 guests
