painting
painting
Postby hidepenny » Tue Jan 23, 2007 11:00 am
Hi guys, if i did a painting course as in house painting or a diploma/cert in paint, would i be able to paint my bike?
like sanding and techqines of apply spray paint evenly?
hidepenny
Re: painting
Postby Jonno » Tue Jan 23, 2007 11:02 am
hidepenny wrote:Hi guys, if i did a painting course as in house painting or a diploma/cert in paint, would i be able to paint my bike?
Not really, auto spraypainter is the go, they do courses at TAFE.
I learnt by myself with a few tips from a mate, not that I am good at it but I did a few cars in my time.
Postby hidepenny » Tue Jan 23, 2007 11:08 am
can anyone suggest any course bike/car related and availabe as partime? as i can't seem to find any :( :(
hidepenny
Postby Lainie » Tue Jan 23, 2007 11:13 am
http://webserver1.chisholm.vic.edu.au/sidemenuindex.cfm?item=portal_ed-short-search3
I am doing the one in March... Have done Automotive couses b4 her and loved them :D
Lainie
Postby icebreaker » Tue Jan 23, 2007 11:42 am
if you wanted to use a paint brush.... lol
you would prob get some benefit in learning to prep.. but you would still need practice in using a spray gun...
you going to trailor it up the spur and paint it?
Ducati Monster S2R1000
icebreaker
State: Tasmania
Postby Lainie » Tue Jan 23, 2007 11:51 am
Lainie
Postby javaman » Tue Jan 23, 2007 11:56 am
You're gonna paint the bike with Dulux ? ...
-ariel circa 2007
http://GPZninja.blogspot.com/
javaman
Bike: GPz900
Postby hidepenny » Tue Jan 23, 2007 12:01 pm
yeah for all the weather and crack proof as seen on tv!!!! :D :D
hidepenny
Postby Duane » Tue Jan 23, 2007 1:24 pm
Do dulux make idiot proof paint ?
www.bromancer.com.au
Duane
Postby Rossi » Tue Jan 23, 2007 1:47 pm
FFS
and think what your saying
Rossi
Postby mfzx6r » Tue Jan 23, 2007 2:18 pm
Dont use water based or a roller :-) :-)
Mario
'01 zx6r
klx300r
Part of the "Fookarwe" tribe
mfzx6r
Postby icebreaker » Tue Jan 23, 2007 3:07 pm
house paint = thick
walls = flat
painter = painter
panel beater = panel beater/sprayer (read not painter)
sanding lines, curves etc is far more intricate than sanding a house and painting with a roller.
House paint is thick and can hide so much. where as spraying something, esp with metalic it can show up ALL the imperfections.
Dust is also a far greater issue with spraying then painting.
best thing to do is get tips find out what steps to take and learn/practice... panel beaters don't just start doing it, they go through several years worth of apprenticeship to get it down to an art.
try it and you'll find that you will learn as you go and keep improving the more you do it.
icebreaker
State: Tasmania
Postby Adel » Tue Jan 23, 2007 5:12 pm
Cant beleave I missd this post, well as a panel beater / spraypainter
I can say it will take a while to lurn how to spray realy good but some
people pick it up quickly, try practicing on an old panel, if you have no
body work to be done such as appling putty well all you do is
* rub panels with 600 or 800 wet n dry make sure you use water, make
sure no shinny bits lefts, then clean it then wipe with prepsol use rags that
dont leave fluf use one for appling one for drying ( must dry it straight
away )
* depending on what group paint you will use, ther is plain colour or
metalic, and also acrylic or two pac enamel, I suggest you use acrylic
cause enamel very dificult to perfect, so choose your colour work out how
much you need and get the auto shop to mix it for you, you must get
some thinners to thin paint
*now if your gonna spray metalic which is the one with kinda glitter in it
then you must spray 6 coats all up 3 colour and 3 clear paint which is a
must for metalic paints it makes it shine, if you gona spray solid colour which
is just colour with no particals in it then you dont need clear paint
* now mask it up to avoid ova spray on bit you dont want to paint
* ther is no need for under coat, I have done many car without under
coat and I havent had any probs, only needed if old paint is realy faded
* when mixing paint mix it in the spray gun pot, it saves a lot of markin about
1st coat mix 40% paint to 60% thinners
2nd coat 30% paint to 70% thinners
3rd coat 20% paint to 80% thinners
4th coat if your not spraying metalic same as 3rd coat
if your spraying clear
1st coat 30 % clear paint to 70% thinners
2nd coat same as first
3rd coat 20 % clear paint to 80 % thinners
get your self a little beaver its good value
* now when you re spraying, hold gun about 8 to 10 inches away then
spray edges first and then go over whole panel at a constant motion with
out stopin , not to fast not to slow make sure you spray closed area to
prevent dust fallin on paint job
* having done all that allow 3 for days for drying time then cut it back
with 1000 or 1200 wet and dry, make sure you use water and when you
rub it back dont rub in the same area for to long but also you have to get
rid of the orange peel look on the job after it has dried, keep wiping water
of to see if orange peel look has gone then buff with buffer ofcourse and
use good quality compound, careful ther is a lot shit out ther
and if you feel this is to much to do then I suggest cookin
glad to help if you have any questions
ZXR 750 j 91
Adel
Postby Rossi » Tue Jan 23, 2007 6:14 pm
adel wrote: get your self a little beaver its good value
I must have gone wrong somewhere........mine costs a fortune to keep happy :lol: :lol:
Orange peel effect in spraying is an indication of :-
A. Incorrect thinning medium used
B. Wrong pressure to your gun
:wink:
Rossi
Postby Daisy » Tue Jan 23, 2007 6:27 pm
The little beaver and the wagner equivalent are rubbish. The only thing you would use them for is something where finish is not important... like fences
or Hondas. :lol:
A couple of hundred bucks will get you a halfway decent compressor outfit that you can build on as your skills increase.
Daisy
Bike: GTR
Next
Users browsing this forum: No registered users and 27 guests
