RGV 250 where to put oil?
Postby Matt_'98ZX9R » Wed Dec 21, 2005 5:53 pm
hey guys
a mate bought an rgv 250 and we're stumped as to where to put the oil. its a 90 model... does it just go into the tank? if so anyone know the ratio?
thakns guys
Matt
Matt_'98ZX9R
Postby I-K » Wed Dec 21, 2005 5:58 pm
Ummm, isn't there an oil tank under the pillion seat?
I-K
Postby Barrabob » Wed Dec 21, 2005 5:59 pm
2 stroke oil goes under the seat, 4 stroke engine oil goes in the gearbox.
Would check with whoever you got it off what sort of 2 stroke oil they where running and whether the oil injection works though first.
Some 2 stroke oils dont mix too well in a injection system and i have read somewhere to use a good quality synthetic 2 stroke oil rather than the stuff they use in lawnmowers.
Barrabob
Postby falomvtr » Wed Dec 21, 2005 6:08 pm
Its under the pillion seat and I always used a synthetic oil in mine. Ran heaps better. :D
Stew
falomvtr
Postby Matt_'98ZX9R » Wed Dec 21, 2005 6:43 pm
thanks guys
that would explain why i cant find it....
no pillion seat :)
will take off rear fairing
Matt
Matt_'98ZX9R
Postby Matt_'98ZX9R » Wed Dec 21, 2005 7:06 pm
should there be a water resevoir under there too?
Matt
Matt_'98ZX9R
Postby Matt_'98ZX9R » Wed Dec 21, 2005 7:29 pm
it used to be a race bike...
any chance they did away with the oil tank and just mixed it in the tank?
Matt
Matt_'98ZX9R
Postby the kid » Wed Dec 21, 2005 8:07 pm
Could be .
Oil injection was to save the hassel of mixing in a drum before riding . It 's so you could just stop at servos like the rest of the crowd .
If you went Racing people would mix to get a better ratio to suit the oil they ran .
the kid
Postby Neka79 » Wed Dec 21, 2005 8:15 pm
pre mixed fuel ratio's approx 25-1 to 40-1 depending on what ur doin...
basically the lower the oil, the bigger the bang (more power) but the more often u rebuild ur motor...
umm sounds like ur gunna b mixing ur own oil too...
also good 2 stroke oil is available from bike shops (wqho will advise of best ratio etc) whereas other cheap shit u can get newhere ...the cheap shit will get u out of a bind..but id use the good shit..
Postby Glen » Thu Dec 22, 2005 7:44 am
If you're premixing, 40-1 is fine in fact you're engine will probably do better than 25-1, which is way too oily for most modern 2 strokes other than your lawnmower. Make sure the jetting hasn't been frigged with too much though. MX race bikes run as high as 60-1 but they do rebuilds regularly.
Whatever you do though, use a real good quality synthetic 2 stroke (highly reccomend Motul) and keep your fuel fresh.
Postby Matt_'98ZX9R » Thu Dec 22, 2005 6:07 pm
heaps of great info
thanks guys will try it this weekend and see how i go
Matt
Matt_'98ZX9R
Postby Stereo » Thu Dec 22, 2005 8:32 pm
ever considered calling the origional owner? or some guy that races those? bet you would find heaps on the uhm.... racing forum thingee
Return to General Discussion
