I was advised by hammer to put a little bit of Methylated Spirits in the tank if that happens again. (thanks stu
I'd like to hear what are your views on this issue, water in fuel tank.
Any 'myths' or 'traditional methods' or 'other methods' ?
RG wrote:I'd like to hear what are your views on this issue, water in fuel tank.
RG wrote:And another question here: Will the Methylated Spirits affect the fuel in anyway?
Felix wrote: Sorry to nerd it up Ratmick, but I must correct you...
Methylated spirits is Ethanol (pure alcohol) to which they add Methyl (Methanol) therefore Methylated. This is because Methyl alcohol is poisonous and the government can't have alcohol being sold for conumption without them collecting an excise, can they?
Felix wrote:
Essentially how it works, is that methylated spirit is bipolar, meaning there is a slightly positive end, and a slightly negative end, allowing it to create weak bonds with both water and oil (petrol) at the same time. This breaks the water down and allows it to pass through the engine without killing performance much.
Felix wrote:Sorry to nerd it up Ratmick, but I must correct you...
Ratmick wrote:I sit corrected, please flagellate me as you pass as I am unworthy.
nobikeatall wrote:Just put LRP in it, that should do the trick!!!!![]()
