Nelso wrote:1st gear, clutch in with two fingers only, give it lots of revs and drop the clutch. Don't slip the clutch at all either, just let it off instantly. Also, lots of revs means WOT. Be ready to shut the throttle off when the front comes up the first few times, but as you get used to it, you will be able to control how high to get the front up and how long to keep it up. Once you can do it on a regular basis, try doing the same thing standing on the pegs.
Cheers! I adjusted the levers (little fingers
Need a whole day just practicing it!
